| Hi, just wondering if there is a device or circuit that will solve my problem? Problem: I have a fish tank filter/pump that needs to be primed (filled with water) so that it will continue to circulate the water. However, when the power flickers or goes out and then comes back on, it has lost its water and no longer circulates the water but the pump keeps going... burning it out. Aside from a UPS that only lasts a few hours, Is there a device or circuit that will NOT allow my filter pump to come back on after a power flicker or loss? Jen. | |
| Wire a relay so that it powers itself in parallel with the load. Also wire a momentary switch so you can turn the relay on.
__________________ If you don't have a planet, what good are gold bars? want to contact me directly? gmail gordonthree check out my project website: http://projects.dimension-x.net Favorite numbers: 09 F9 11 02 9D 74 E3 5B D8 41 56 C5 63 56 88 C0 | |
| oh, a picture is worth 1000 words right? be careful when you're working with AC power.
| Buy a better fish pump? The one's we have for our tanks will dry prime as long as the water level in the tank is normal and the filter isn't clogged. They're driven via an issolated induction motor and it's not possible for them to burn out even if the impeller is completly locked, and these are cheap pumps. You might be talking about a mucher larger tank? If this is really a problem you'll need to find a different pump design such as one that will self prime and can dry run indefinitly. They're generally more expensive than basic pumps but will last effectivly a lifetime.
| What make and model of pump do you have? | |
| I'm thinkin' check valves at the ends of the line, but inside the length of what the pump considers primable head. Don't plug it into the UPS, then it stays off during a power failure, but has held prime to allow a restart when the power returns. This is used with some sump pump systems, where a loss of prime could result in no pump, an possible flooding. | |
| Where would I find a check valve to fit inside my filter tube that draws up water from inside the tank? | |
| 1. Use No voltage release switch such as CA25X from Kraus & Naimer. 2. Place your water pump below the water level so that the pump will be always filled with water. Last edited by t.o.; 1st June 2007 at 04:14 AM. | |
| Drip coffee makers have check valves... | |
| **need help with AC to DC and DC to DC power supply TT** | ahdehling | Electronic Projects Design/Ideas/Reviews | 5 | 25th June 2007 09:40 PM |
| DC power through Var. AC Xformer -> Wart | ArtemisGoldfish | Electronic Projects Design/Ideas/Reviews | 3 | 6th May 2007 09:38 PM |
| Ultra low power power supply | steevke | Electronic Projects Design/Ideas/Reviews | 1 | 3rd February 2006 04:46 AM |
| Power Supply for a project to be powered within an Auto? | hexibot43 | General Electronics Chat | 16 | 8th September 2005 03:36 PM |
| PIC power supply problems | evandude | General Electronics Chat | 5 | 2nd March 2004 08:39 PM |
