+ Reply to Thread
Results 1 to 6 of 6
Thread: isd voice chip
  1. #1
    Gaston Okay
    Join Date
    Jun 2004
    Location
    USA
    Posts
    468
    Default isd voice chip
    is anyone familur with the isd voicechips?? I am using the isd1110. i recorded the chip on a board that i bought and the chip sounds real good. but when i put it on the playback board i made it doesn't act right. i made the board to continuosly loop the sound. i am holding pin 23(which should play when held low) low. and it play throut the speaker output but not the analog out. and it stops when it hits the end of message marker. i have pins 3,9, and 10 held high which acording to the data sheet should put it into a special looping mode. am i overlooking something?
  2. #2
    Gaston Okay
    Join Date
    Jun 2004
    Location
    USA
    Posts
    468
    here is the schematic. i had to draw it up in multisim
  3. #3
    Gaston Okay
    Join Date
    Jun 2004
    Location
    USA
    Posts
    468
    ok, what i am gathering from the aplication notes is that the analoge out is the output from the microphone preamp and is meant to be fed back into the analoge in for recording. why would they want to do this? an effects loop? : ) . so you must have to take the output from pins 14 and 15. i get good out from these pins. but i still have a looping problem. in the note it says that mabey i recorded past the end of the memory. let me go out to my lab and record a shorter recording and see what happens. i will post my results
  4. #4
    Gaston Okay
    Join Date
    Jun 2004
    Location
    USA
    Posts
    468
    i tried a shorter message but i still get the same results
  5. #5
    Gayan Soyza Excellent Gayan Soyza Excellent Gayan Soyza Excellent Gayan Soyza Excellent Gayan Soyza Excellent Gayan Soyza Excellent
    Join Date
    Oct 2006
    Location
    Colombo
    Posts
    1,664
    Blog Entries
    1
    I think you have to make HIGH these pins 4 (A3), 9 (A6), 10 (A7) to make the loop back.
  6. #6
    Gaston Okay
    Join Date
    Jun 2004
    Location
    USA
    Posts
    468
    Thanks Gayan, i had pin three high instead of four. i guess because it is called A3 i got it confused. that did the trick. it works now. an extra set of eyes helps out sometimes
+ Reply to Thread
  1. voice recognition chip....
    By aspil in forum Datasheet/Parts Requests
    Latest: 26th February 2010, 09:26 PM
  2. ISD 1700 series minimal sound
    By hack in forum General Electronics Chat
    Latest: 24th September 2009, 04:07 PM
  3. Good Electronic Supply's Sites, Everyone Come On In! :P
    By Electric Rain in forum General Electronics Chat
    Latest: 27th August 2007, 11:06 PM
  4. voice record/playback from chip
    By akg in forum Datasheet/Parts Requests
    Latest: 28th September 2005, 08:23 AM
  5. generic voice comparator module
    By shaune07 in forum Electronic Projects Design/Ideas/Reviews
    Latest: 26th July 2005, 05:29 AM
Tags for this Thread
