The Scenix chips are pretty obscure, and have never managed any sort of market penetration, but may well be perfectly fine for your purposes?. However, do the Parallax chips include hardware I2C interfaces, which are really essential for I2C slave operation (the 16F84A doesn't either, but there are plenty of more modern PIC's that do). I would suggest you don't get 'hung up' on MIPS, from the looks of your requirements high MIPS are of no use to you - and I would suggest all you need is small modern PIC's with internal 4 or 8MHz oscillators, and I2C hardware. |
the 84 is an ancient chip, hence the high price
check out the 16F884 ... 4k, 35 IO pins, hardware I2C (or spi) port, flexible onboard clock generator (32khz-8mhz), roughly $2.50 mips aren't everything. 20 mips is hardly "slow" - speed comes from efficient programming, relying on instructions per second is just a crutch for sloppy code.
If you don't have a planet, what good are gold bars? want to contact me directly? gmail gordonthree check out my project website: http://projects.dimension-x.net Favorite numbers: 09 F9 11 02 9D 74 E3 5B D8 41 56 C5 63 56 88 C0 |
The chip runs at 75MIPS. Not the basic that's run on it.... Even 1MIPS is incredibly powerful if you have hardware level access.
could, mum, but I be a cat, and no cat anywhere ever gave anyone a straight answer, har har." Last edited by Sceadwian; 20th May 2007 at 04:02 AM. |
(permalink) | ||
Also, forgive me for being ignorant, but why does the i2c interface need to be hardware driven for slave applications? Scenix provides software i2c source code for "authentic i2c master/slave interface" HERE Last edited by oeginc; 21st May 2007 at 10:35 PM. |
"you can do reasonably well emulating i2c timing with a software uart, but why bother when Microchip has a Philips certified I2C Master/slave interface built right into the chip."
I have a PIC16F88 and some folks are telling me that the only way to use it as an I2C master (controlling a 24LC512) is to write code that controls the pins individually (called bit banging I believe). I have such code already but it ties up the microprocessor. I need to know if it is possible to use the internal hardware to impliment an I2C master, in particular how the pic88 hardware sees the ack signal from the slave. I am writing my code in assembly language because that is all that I know (for working with the pics). I already wrote code (with much assistance) that uses the usart hardware to talk to the serial port. That part of the project is finished. |
small point from a pedant; 16f84 runs up to 20MHz, that's 5mips on a pic.
for your simple applications, the faster the processor the more times it will perform delay loops. |
| Wireless I2C | adamthole | Electronic Projects Design/Ideas/Reviews | 5 | 24th April 2007 01:13 PM |
| WRT54G Power Supply Chip | ParkingLotLust | Datasheet/Parts Requests | 32 | 5th January 2007 09:26 PM |
| Chip Identity | edcross1 | General Electronics Chat | 5 | 21st July 2005 07:51 PM |
| little help with my program please - simple count loop | kud0s | Micro Controllers | 5 | 7th July 2005 09:40 PM |
| simple help.. Making a simple amplifier. pls help urgent. | paulbostaph | General Electronics Chat | 19 | 20th May 2003 04:32 PM |
