+ Reply to Thread
Page 1 of 3
1 2 3 Last
Results 1 to 15 of 35
Thread: Windscreen wiper motor questions
  1. #1
    bitem2k Newbie
    Join Date
    Jan 2007
    Location
    England
    Posts
    201
    Default Windscreen wiper motor questions
    I recently salvaged an old windscreen wiper motor from a car.
    The Motor has four terminals. Ive got two of them connected and it seems to work fine, is this right?
    I intend to run the motor for hours at a time, and i would imagine that they are capable of that. I sometimes drive for hours in the rain and i would have my wipers on for the entire time.
    If i run it for hours, it gets realy hot, and stays that way for about 30minutes after i turn it off. Is it meant to get that hot?
    Thanks very much.
  2. #2
    RODALCO Newbie
    Join Date
    May 2006
    Location
    Akld, New Zealand
    Posts
    937
    bitem2k
    It shouldn't be too hot to touch.
    Certainly you shouldn't burn your fingers on it.
    What are you driving with it. The loading may be too heavy for the motor.
    It is usually a series motor, check that the armature is in series with the field windings.
    Please don't sent me private messages, I will not answer them.
    The questions asked can be discussed in the open forums.
    http://www.youtube.com/user/RODALCO2007 some interesting electrical stuff to watch.
  3. #3
    bitem2k Newbie
    Join Date
    Jan 2007
    Location
    England
    Posts
    201
    Quote Originally Posted by RODALCO
    Its def. hot enough to burn yourself on.
    It overheats with no load
    Im sorry can you please explain that to me, I know nothing about motors.
    thanks
  4. #4
    Rolf Good Rolf Good Rolf Good
    Join Date
    Jun 2006
    Location
    E. Tennessee, USA
    Posts
    652
    Default Not 12V ......... ?
    Quote Originally Posted by bitem2k
    Thanks very much.
    Depending on how old the car was that the wiper motor came out of, it could be a 6V motor.
  5. #5
    3v0
    3v0 is offline
    3v0 Excellent 3v0 Excellent 3v0 Excellent 3v0 Excellent 3v0 Excellent 3v0 Excellent 3v0 Excellent 3v0 Excellent 3v0 Excellent 3v0 Excellent 3v0 Excellent
    Join Date
    Jul 2006
    Location
    USA
    Posts
    6,464
    Blog Entries
    11
    You need to figure out what each of the 4 wires do. It is possible that although you have it running it is not hooked up as intended.
    When you turn a wiper motor off it runs long enough for the wipers to go back to the rest position. I think that means there is a always on wire to power the unit while it returns to the rest position. (1 wire)
    In most cases there are at least two speeds. (2 wires)
    Maybe a ground (1 wire)
    Could also be that the motor is grounded through the case and you are using a wire for ground.
    In the following page the author hooks an H-Bridge to one.
    http://www.ayershome.org/~eric/robots/hbridge/index.shtml
    BCHS/3v0's Tutorials
  6. #6
    Join Date
    Nov 2003
    Location
    Derbyshire, UK
    Posts
    29,792
    Wiper motors are pretty sturdy devices, they are often used in medium suzed robot project, and generally last extremely well, even when fed from 24V rather than their designed 12V. One problem with them is that they are only designed to rotate in one direction, and the brushes and bearings are designed accordingly.
  7. #7
    Friend of the Electrons Andy1845c Good Andy1845c Good Andy1845c Good
    Join Date
    Apr 2006
    Location
    Southern Minnesota
    Posts
    1,156
    Do you know if it was working when it was in the car? They are pretty tough, like Nigel said, but if it came out of a car thats been sitting for years maybe its rusty or gummed up inside. How does it feel when you spin it by hand? smooth and free or stiff and rough?
  8. #8
    bitem2k Newbie
    Join Date
    Jan 2007
    Location
    England
    Posts
    201
    thanks all for replies.
    I took it out of my sisters car, the engine had died recently, the wipers functioned fine.
    I cant really spin it by hand, its quite hard to move it. I thought that was because of some kind of internal gearbox?
    The motor has a black 4 pin plug attached to it, going into this plug (from the motor) are two wires, red and yellow.
    If i connect the first pin and the last pin, the motor spins quickly.
    If i connect the last pin and the pin next to it, the motor turns slowly and in reverse direction.
    Does this help?
    thanks
  9. #9
    bitem2k Newbie
    Join Date
    Jan 2007
    Location
    England
    Posts
    201
    Quote Originally Posted by Nigel Goodwin
    Nigel, do you think im running it the wrong way? Would that cause enough heat to fry an egg or even a nice juicy bit of steak?
  10. #10
    Join Date
    Nov 2003
    Location
    Derbyshire, UK
    Posts
    29,792
    Yes, you can't turn it because of the internal gearbox - you should be connecting it so it runs fast, that's probably a direct connection to the motor. Usually one of the motor connections will be connected to the metal body of the motor, that should be the negative connection.
  11. #11
    bitem2k Newbie
    Join Date
    Jan 2007
    Location
    England
    Posts
    201
    If im connecting the motor up the wrong way round, ie (+ to -) and (- to +) opposite to which manufacturer intended,
    do you think that would cause the heating?
    thanks
  12. #12
    Join Date
    Nov 2003
    Location
    Derbyshire, UK
    Posts
    29,792
    Possibly, it's only intended to turn one way, try it the other way and see if it still gets hot - but electric motors DO get hot.
  13. #13
    bitem2k Newbie
    Join Date
    Jan 2007
    Location
    England
    Posts
    201
    by hot, do you mean HOT! or just hot.
    thanks
  14. #14
    HarveyH42 Excellent HarveyH42 Excellent HarveyH42 Excellent HarveyH42 Excellent HarveyH42 Excellent HarveyH42 Excellent HarveyH42 Excellent
    Join Date
    Feb 2006
    Location
    Florida
    Posts
    3,081
    Okay, 4 wires... You have 2 speeds, there is a 'Home' sensor so it doesn't stop in the middle of the windshield (windscreen), not sure if its one or two wires, almost all automotive ground to chasis. The gearhead in the one I took apart many years ago had a worm gear, so gotta go with the on direction deal. Put (-) to the case, and 2 of the 4 wires should make it go...
    Since it got hot enough to mention, guessing very hot. I'd open the gear head and see if there is damage, and just to make sure its well greased after the melt. Makes a big difference...
  15. #15
    Join Date
    Nov 2003
    Location
    Derbyshire, UK
    Posts
    29,792
    thanks
    I can't say I've ever had any occasion to feel a wiper motor!
    But electric drill and vacuum cleaner motors get too hot to touch.
+ Reply to Thread
Page 1 of 3
1 2 3 Last
  1. max5450 digitalpot & pic16f877a question
    By spacecowboy in forum Micro Controllers
    Latest: 10th January 2007, 10:47 PM
  2. Sensor for auto car windshield wiper?
    By harore in forum Electronic Projects Design/Ideas/Reviews
    Latest: 18th October 2006, 01:20 PM
  3. windscreen slammer circuit
    By dulanjana in forum Electronic Projects Design/Ideas/Reviews
    Latest: 25th January 2004, 10:47 AM
  4. windshield wiper motor
    By electricano in forum General Electronics Chat
    Latest: 27th December 2003, 10:11 AM
Tags for this Thread
