Hi guys, im new at the forums, i did a little research here and it was really helpful. now i need help with my project. im trying to make a circuit for my mustang. to make my tail lights work on a sequence like old t-birds. i found a schematic and i made but here is the thing. when i push the brake, the inside lamp and the midle lamp lit up at the same time. i wanted to know what you guys think should be the problem here. the only thing different i did was. change the 250k trimmer for a 200k and 100k resistor instead of 150k the resistors insted of been 1/4w, i used 1/2w. do you guys think that would be my error. also i tough that when i pushed the brake the sequence would also restart but they dont. they just lit up on a sequence but they stay on.
this is the schematic i used https://home.comcast.net/~jormendoza/1.pdf thanks for the help. |
Looking at the timing of the c,m,o lamps there is very little time difference. By changing the 250K to 200K and the 100K to 150K you have probably moved the timing adjustment outside the range you want. You could connect a 47K0 in series with 100K, make it nearer 150K. If you have two 0.68uF caps in your scrap box, replace the 0.47uF's, this will increase the switch ON delay. There are number of points on the circuit that could cause problems.
Eric "Good enough is Perfect" PIC tutorials: Gramo's: www.digital-diy.net/ Bill's: www.blueroomelectronics.com/ |
cool thats something logic i dindt think about.
Maybe ditch that design and use a microcontroller ?
That way you could program it to do whatever you wanted.
search engine for electronic partsJunebug USB PIC programmer kit., USB Bit Wacker, Homepage The 15 Minute Printed Circuit Board! (+drill time) |
i was thinking like on a 555 timer and a cmos 4017 but i dont know how to figure out the rest of the parts i'd need.
You might not want to have your brake lights blinking; if it happens to confuse someone you could end up with all your lights broken (car, too).
They were standard on T-Birds and starting in 65 for a few years and some courgars. IIRC the original units do it with motors and wippers.
I suppose the could have made the illegal for cars not originaly equiped with them but I do not recall that ever happening. This could be breadboarded with a microprocessor. If you used LEDs as the tail lights on the breadboard it would look somthing like this. I picked a random 18 pin chp only used 8 I/O pins. The lines LEFT and RIGHT are inputs from the autos flasher module. On the real circuit a voltage divider and zener would be used to get a safe 5V from LEFT and RIGHT. Replace the middle and center LEDs with transistors to drive the 12V bulbs. Voltage regulation for the processor. Code should not be difficult.
search engine for electronic partsJunebug USB PIC programmer kit., USB Bit Wacker, Homepage The 15 Minute Printed Circuit Board! (+drill time) Last edited by 3v0; 16th May 2007 at 06:47 AM. |
Sequential turn signals are probably still legal in the US.
However I wouldn't be so sure about repetitive blinking brake lights. Then again, some of the newer buses have bright red and yellow lights that flash when the brake is first applied and then go to steady red at normal brightness when the vehicle comes to a stop. |
is there anyway i could delay the midle and outside lamp, just usisng resistors and capasitors ? or i really have to use a chip to drive it. like just putting a resistor and a capacitor betewen midle lamp and outside lamp so they lit up in sequence but with a litle delay from the inside and eachother. can i do that ?
If it was that easy FoMoCo would have done it int the 60's. Instead they build an expensive complex box with motors wipers and relays.
How are you going to determine when to lite the brake vrs the turn signal. With a processor you know it is the brake because power is applied to right and left at the same time. By the time you paste enough components in to make it work you may as well have used a processor. With a processor if you goof you reprogram it. You can buy a box on EBay that does this for about $190.
is there anything else i can use instead of mofset inrf9530, i have one done already and second one i only need the mofsets but nobody has it around here, is there any other i can use.
I don't believe there was a wiper/motor system on the T-bird sequential lights but I'd like to see it. They aren't as anti-techno as you'd believe, even in the early 60s. Power windows, AC, cruise control, etc were normal options.
You can also do it the easy way: http://www.mustangsplus.com/Merchant...ial_tail_lamps |
(permalink) | ||
I have a 65 tbird that I last drove in the 80's. The car has a serious fun/cool factor. Also need serious work but has no rust.
The signal lights use a motor/cam (not motor/wiper as I said) system. Link to ThunderBird Ranch where I found the following. Quote:
its ready and works great. thanks for the help guys.
| Trailer Electrical Wires | daviddoria | General Electronics Chat | 9 | 3rd November 2007 08:12 AM |
| Turn signals on my motorcycle.... | frog | General Electronics Chat | 4 | 29th May 2006 10:23 PM |
| Pic Basic Pro / PIC Problem | Tako Kichi | Micro Controllers | 7 | 11th January 2004 10:46 PM |
| Turn on and off air valves | thup | Electronic Projects Design/Ideas/Reviews | 16 | 27th December 2003 03:19 AM |
| help with sequential turn signals | sjw32 | Electronic Projects Design/Ideas/Reviews | 2 | 21st February 2003 02:03 PM |
