| ...as I respectfully kneel at the bloody-orc alter... I humbly submit the following question.... Ok, so my layout is done, only 2 or 3 minor clearance errors... but there is a what appears to be a section of trace ( hashed tho, not solid ) in the middle of no-where o my PCB. Also the little clearance hashed areas won't go away after I fix the clearance... what's going on? Is the small track segment some accidental trace placement? Why is it in hash instead of solid? It is in a place that if reproduced by the maker, it will short 2 traces. The 2 traces are far enough apart, but this little bit is in the way. Thnaks! | |
re-run the DRC check ... if it passes, the hatch marked areas will clear you can also hit the delete all (or is it clear all) button when the drc error list comes up.
__________________ If you don't have a planet, what good are gold bars? want to contact me directly? gmail gordonthree check out my project website: http://projects.dimension-x.net Favorite numbers: 09 F9 11 02 9D 74 E3 5B D8 41 56 C5 63 56 88 C0 | |
OK, that makes sense. I tried moving the track to get the clearance, but the bit was still there. I guess I should just try deleting it via the DRC ( I am sure I tried selecting the delete tool then clicking on the item, no-go .) It is weird though, it is in the color of that layers tracks ( blue ) and appears as if it were a vestigial trace. Other clearance hashes are a separate colour, say an orangish tone IIRC. Thanks! | |
| debris, eagle, error, left, pcb |
| How to properly do PCB edge connections in Eagle? | toodles | Electronic Projects Design/Ideas/Reviews | 2 | 10th April 2007 11:36 PM |
| PCB board manufactuing house recommendation | meriad | General Electronics Chat | 16 | 5th March 2007 06:57 PM |
| Achieving a smaller trace width in Eagle | evandude | General Electronics Chat | 8 | 10th February 2007 10:51 PM |
| Eagle import/export -> Protel SE | midnitrcr | Electronic Projects Design/Ideas/Reviews | 0 | 10th November 2006 09:54 PM |
| smd's in Eagle | justDIY | Electronic Projects Design/Ideas/Reviews | 1 | 31st July 2005 09:22 PM |
