Old 12th May 2007, 02:29 AM   (permalink)
Default Surface mountable Capacitors/Resistors
I am currently developing a schematics using eagle, and there is a C1206 (US) surface mountable capacitor. I know that in my local electronic store they do have some surface mountable capacitor. Do you think they will have 1uF capacitors, or do surface mountable caps are in order of pFs?
Also, I would like to use surface mountable resistors, are there any limits on those too? I was thinking about using R-US_R1206.
As for the surface mountable caps/resistors, are there any restrictions on the capacitance/resistance/power?
Thank You,
Vlad.
BOBKA is offline
Old 12th May 2007, 02:56 AM   (permalink)
No way of knowing. Maybe you should tell us where you are. It's a small world, but not that small.
1uF is commonly available as a surface mountable capacitor; I'm sure some are made in size 1206.
mneary is offline
Old 12th May 2007, 03:01 AM   (permalink)
Hi Vlad,
Well I don't know about your store, but I have a roll of .1uF here. They are marked 16 volt 10%. They are small size 0603. I think this means 6mm x 3mm. The 1206 would be 12mm x 6mm, if I'm thinking correctly. (I'm new at surface mount too.) I also have 0805 caps rated at 100 volts, so I know there are a range of voltage ratings. You should be able to get most any value available in ceramics, in a surface mount package.
I have some 1206 1% and 0805 5% resistors rated at 100mW, and I've seen 1206 rated at 250mW. Vishay has a 1 watt 1206 resistor, so by searching around you should be able to find what you need.
Sorry I can't be of more help, but if you google on 1206 smt resistor, or capacitor, you will get lots of info.
BeeBop is online now
Old 12th May 2007, 03:52 AM   (permalink)
Alright guys, thanks alot.
Just to make sure I will go to the store tomorrow and check it
BOBKA is offline
Old 12th May 2007, 09:25 AM   (permalink)
almost everything made for through-hole is made for SMD. (actually more things are made SMD than holed). Resistor wattage goes to 1W IMHO (if not more). Also you can get virtually any capacitor for SMD.
I know, I use those things for every board I make... Much more cost effective you know... (and also neater)
Need Help?
Press F1
If that doesn\'t help you, ask me... I might know better.
bloody-orc is offline
Old 12th May 2007, 02:12 PM   (permalink)
You can get surface mount capacitors in most sizes, the smallest I've seen is 1pF at 50V and largest I've seen is 2200µF at 35V.
Screen name: Aloone_Jonez
Hero999 is offline
Old 12th May 2007, 06:02 PM   (permalink)
Are you doing soldering iron, toaster oven, or fry pan ?
3v0 is online now
Old 12th May 2007, 08:55 PM   (permalink)
Here is a small tutorial (but very good) about conventions used in eagle choosing the right parts:
http://www.instructables.com/id/ENUTEALRUXEQHO8Y6O/
BOBKA is offline
Old 13th May 2007, 03:21 AM   (permalink)
0603 should be 0.6 mm x 0.3 mm, the size is length and width in tenths of a millimeter
If you don't have a planet, what good are gold bars?
want to contact me directly? gmail gordonthree
check out my project website: http://projects.dimension-x.net
Favorite numbers:
09 F9 11 02 9D 74 E3 5B D8 41 56 C5 63 56 88 C0
justDIY is offline
Old 13th May 2007, 03:49 AM   (permalink)
Yea, OK; that makes more sense, thanks! 12mm x 6mm would be huge!
Old 13th May 2007, 01:53 PM   (permalink)
Those dimensions seem small compared to what I measure. Some references show that the SMD size is equal to the dimension in hundredth's of inches. That is, an 0805 resistor is 0.08" long (about 2mm) and 0.05" wide (about 1.27 mm), which agrees better with actual measurements. John
jpanhalt is online now
Old 13th May 2007, 02:09 PM   (permalink)
the numbers mean size yes. but in mil's (actually mil*10)
0805 is 80mil * 50 mil (mil != mm)
Need Help?
Press F1
Old 13th May 2007, 02:37 PM   (permalink)
A mil is 0.001 inches, it's nothing to do with millimeters.
Hero999 is offline
Old 13th May 2007, 02:55 PM   (permalink)
Try these sources:
http://www.fpga4fun.com/external/SMD/smdman.pdf (see: page 6)
http://www.radio-electronics.com/inf...d_resistor.php
http://www.answers.com/topic/surface-mount-technology
http://smdin.com:8080/explainedinbrief.html
That why I keep the grid in Eagle set on inches! Sorry, Bloody-orc
John
Old 13th May 2007, 03:14 PM   (permalink)
Thanks John!
Those links are full of valuable info for someone just getting started with SMT.
How to deal with Surface Mounting components aljamri Electronic Projects Design/Ideas/Reviews 17 24th February 2007 12:13 PM
surface mount soldering techniques Richard Principal General Electronics Chat 5 12th November 2006 05:44 AM
replaceing surface mount with normal size capacitor mikee55 Electronic Projects Design/Ideas/Reviews 17 22nd January 2006 11:04 PM
surface mount type chips charliec General Electronics Chat 5 23rd March 2005 10:16 AM
16F84A surface mount Johnson777717 Micro Controllers 4 28th June 2004 06:26 AM
