Old 8th May 2007, 07:41 PM   (permalink)
Default Divide by N
Hello board ^^, just recently someone got me involved in a project where they are making hydrogen gas for their car with electrolysis. They got me building all the electronics for it, and they are doing the mechanical aspect. I have everything about 80% done, expect for one part:
One sub-circuit requires a divide by N where 1000 input pulses = 1 output pulse. The circuit is using a CD4059, the problem is that the schematic only shows a block diagram for that part o.o.
The chip itself is considered obsolete, I managed to order 5 of them, but I can't figure out how to get it to divide by 1000?
If anyone can help me, I will greatly appreciate it. Also, a modern or different way of doing it is welcome, but as I said I have 5 of the CD4059's.
windozeuser is offline   Reply With Quote
Old 8th May 2007, 07:47 PM   (permalink)
Well here is a link to a data sheet that should explain how to wire and configure the divider to your requirements...
http://www.futurlec.com/4000Series/CD4059.shtml
Leftyretro is offline   Reply With Quote
Old 8th May 2007, 08:42 PM   (permalink)
i think the "modern" way is to count the pulses using a microcontroller and dividing in firmware
Glyph is offline   Reply With Quote
Old 8th May 2007, 08:47 PM   (permalink)
I agree with Glyph. For every problem there is a micro controller solution A small PIC could be a modern and cheap option.
eng1 is offline   Reply With Quote
Old 8th May 2007, 09:35 PM   (permalink)
Yeah I have the datasheet myself, but I can't figure it out lol. Well, I want to avoid using a microcontroller in this design.
Old 9th May 2007, 02:57 AM   (permalink)
Is "n" always equal to 1000 or is it variable?
Jeff
jbeng is offline   Reply With Quote
Old 9th May 2007, 03:27 AM   (permalink)
You can get divide by 1024 using a series of flip flops or a pair of 8bit ripple counters with the output being the 11th bit.
Why do you want to avoid micro controllers in your design?
straight answer, har har."
Old 9th May 2007, 03:58 AM   (permalink)
the N will always have to be 1000. The input is the output of a 555 timer,which can vary from 10 to 90KHz, I need the CD4059 or equivalent that will divide that by 1000 for example:
input is 19000 Hz, output from CD4059 will be 19Hz.
This has to be done by Friday, and I don't currently have any micro controllers in stock. I was figuring it would easier and faster to use parts already available. How would I do that with flip flops?
1024 would probably be fine, do you have an example schematic? this has to fit on a small PCB, so the discrete components can't be much larger than the size of that CD4059, it can be a little larger, probably 2 flip flops max?
thanks
Old 9th May 2007, 04:09 AM   (permalink)
Well I actually looked it up....
The CD4059 is a programmable divide by N counter where N is between 3 and 9999..... You already have the solution to your question in your chip stock. A simple Google search will provide you with a CD4059 PDF file with all the information you need to use it..
It's customary on forums not to ask questions while stateing in the same post that you already have a chip which will do what you want without at first trying to find the most basic amount of information about what you're asking.
Old 18th June 2008, 07:25 PM   (permalink)
Default windozeuser
set ka,kb and j13 to a high all other jam inputs to lows also latch(pin2) low.
I set mine this way, I have a 17 hz freq. Now my problem is, I have a 17k hz
10v input wave 17hz spike out put.
jrstiffany1 is offline   Reply With Quote
Old 18th June 2008, 07:27 PM   (permalink)
Default windozeuser
input freq
____I---I___
out put freq_____I______I_____
Old 18th June 2008, 08:54 PM   (permalink)
But for a small job a uC may be overkill, and it can be easier and cheaper to just use a discrete solution.
You can use a CD4060B 14-stage counter. Just pick off Q10, the 10th stage output, which will give you a divide by 1024 square-wave output.
Carl
crutschow is offline   Reply With Quote
Old 19th June 2008, 02:32 AM   (permalink)
This is generally a bad idea if you plan on making it easy to repair once you leave the group. Use standard components whenever possible.
salgat.blogspot.com
Salgat is offline   Reply With Quote
Old 19th June 2008, 07:03 AM   (permalink)
3v0
Default Observations
It is hard to imagine a hydrogen powered car without a custom uC control system. If they can keep the control system running they can manage a 8 pin uC in the hydrogen generator. Could be wrong.
Using a uC should be better then using obsolete parts.
Efficient use of electricity for hydrogen generation is important. The uC solution would provide some degree of flexibility.
Program a few extra uC's if you want spare parts. At about 50 cents each you can afford a few.
3v0 is offline   Reply With Quote
Old 19th June 2008, 03:33 PM   (permalink)
Using a uC for the simplest of jobs may be okay but it's certainly not a simple task.
1. You need an understanding of the uC operation: speed, memory, registers, commands, I/O characteristics, counters, built-in A/D, D/A, etc.
2. You need to know programming (certainly not trivial).
3. You need a programming fixture designed for the selected uC to enter the program into it.
When it is proposed that a uC be used for a task, it is implicitly implied that all the above is available. It may not be. You have to judge if the above is reasonable or available to do the desired task.
Carl
CD4059A Divide by N Chip HELP Crazy Inventor General Electronics Chat 21 1st August 2008 12:48 AM
TTL, divide by 24 and 12 RODALCO Electronic Projects Design/Ideas/Reviews 3 10th December 2006 09:11 AM
HEF4059 divide-by-n counter - doesn't divide captainhannes Electronic Projects Design/Ideas/Reviews 5 7th November 2006 12:27 AM
Divide by zero warning scout_54 Electronic Projects Design/Ideas/Reviews 1 16th March 2004 07:21 PM
¿1 Hz oscillator? LApprenti Sorcier Electronic Projects Design/Ideas/Reviews 12 20th November 2003 06:25 AM
