I am a newbie to the field of electronics. I am 13 years old and I am greatly interested in knowing the deep levels of gadgets. I need help in constructing a RC car which can move forward , back , right and left. I will be happy if anyone tells me the basics and the circuit diagram of this thing , and the purpose of each component in the circuit. I opened a similar RC car working at 49Mhz and there was a small PCB inside it which had a RX-2 microcontroller and the Remote control transmitter had a TX-2 Microcontroller,,and there were several resistors and capacitors. I am a complete zero in electronics. I would be happy if someone helps me to understand the whereabouts in such a PCB and lifting myself building a successful electronic circuit. At present I need to know what happens in that PCB of the RC car . Please explain me step be step with a circuit diagram and the functions, works , role of each component in a PCB of a RC car.Here are some foolish photos taken by me of the receiver and the transmitter. I know that this will be of no use to you. I just want to show you. Receiver: http://freeze.110mb.com/DSC01087.JPG http://freeze.110mb.com/DSC01088.JPG Transmitter: http://freeze.110mb.com/DSC01089.JPG http://freeze.110mb.com/DSC01090.JPG Last edited by sabharish; 1st May 2007 at 09:42 AM. | |
RX-2 and TX-2 and are not micro-controllers, they are Receive and transmit modules for the wireless link, you will need these to control the car remotely. Have you worked out the mechanical parts, or managed to source them, you probably have some designs for the car , if not I suggest you start by making them... thanks arun | |
A variable resistor in the switch of the TX indicates to the TX main IC that the stick has been moved. That IC then sends a signal via radio crystal down the antenna, probably in an FM signal. The RX antenna then picks up the signal and converts that signal into PWM signal which works at about 50hz. To a servo or motor controller which then converts the signal into power to the motor or the position of the servo. All this would seem basic to the casual observer however this is definitely not a project for the beginner. | |
I could understand some bits of info that was replied. Can anyone post a simple circuit diagram of the Receiver and the Transmitter | |
Hi sabharish Although I would say that you have definately come to the right place with your question, I must agree with some of the other posters: Unless you are a very gifted person, the only way to go is the long one. Start with the basics of electronics and work your way up. I've been working professionally with electronics for a few years, and I couldn't just sit down and make these kinds of circuits (of course that doesn't tell you much, since I could just be an awful technician, but still you should consider this fact). In any case, I hope for you that you will dive deeper into electronics. Its such an interesting and rewarding field to work in - And do prepare yourself for a healthy mental challenge ![]() Good luck whatever you decide! | |
| | #6 |
Isnt it easier to just buy one?.......... | |
| car, constructing, controlled, radio |
| Computer Controlled Radio-Controlled Car help | Suds | Electronic Projects Design/Ideas/Reviews | 6 | 29th March 2007 10:23 AM |
| Replacing crap car radio with a stereo input jack and amplifier. | bitem2k | General Electronics Chat | 11 | 26th February 2007 01:33 PM |
| Radio controlled camera switch | tony-ellis | General Electronics Chat | 7 | 20th April 2006 11:22 AM |
| radio controlled project with at least 2 channels | keile | Electronic Projects Design/Ideas/Reviews | 2 | 27th August 2004 10:42 PM |
| how to make a radio controlled relay ? | truenoteno | Electronic Projects Design/Ideas/Reviews | 2 | 30th June 2003 12:15 PM |
