With a PC modem (voice/fax) can I write a program that monitors the phone line for incoming calls, answers every calls after, say, 5 rings, and, most importantly, turns my phone line into something like the toll-free 1800-xxxx service? I am expecting it to play a voice message 'Welcome to..... Press 1 to.... Press 2 to....' then respond to each digit pressed by the caller accordingly. I know that this has something to do with detecting the DTMF generated when each digit is pressed. But when looking at the modem manual, especially the ATx instructions, I could not find anything useful...
I found in another forum that it is difficult to detect DTMF using a modem but still wonder if this is possible? |
Eric "Good enough is Perfect" PIC tutorials: Gramo's: www.digital-diy.net/ Bill's: www.blueroomelectronics.com/ |
Some modems can do this, and actually come with suitable software as well, but such phone systems generally really piss people off - I know they do me!.
nigel,
I subscribe to the p*ss off bit. When I phone my Doctor for an urgent appointment, I go thru at least 4 levels of options, only to be told at the end, 'the surgery is now closed'
you need something called IVR (interactive voice response) software. a voice modem is required, as it passes along voice channel frequencies over its serial connection, including the dtmf. the modem itself is not used in decoding the dtmf, that is done by the IVR software.
check out asterisk it's a great and powerful PBX package, and includes lots of IVR abilities.
If you don't have a planet, what good are gold bars? want to contact me directly? gmail gordonthree check out my project website: http://projects.dimension-x.net Favorite numbers: 09 F9 11 02 9D 74 E3 5B D8 41 56 C5 63 56 88 C0 |
(permalink) | ||
if u hv a voice modem try and download a software called supervoice...i hd some years back written some routines for a internal modem....also chk out google for sdk
as far as my knowledge goes...u can use any voice capable modem which comes in very cheap these days. All of them can / hv dtmf tone generators built into it. As they modem has a built in dialer. If u need to go for multiport IVR, then look for products like Dialogic or IBM Wave etc...they are multiport and more expensive. |
I'm trying out Asterisk. Wasting a lot of money calling my fix line from my mobile phone to test the software.
@dandy: what do you refer to my multiport IVR? |
dialogic et all are commercial substitutions for asterisk.
if you're working on this for fun, there's no point in buying a commercial ivr package. as far as multiport, how many ports do you need? there used to be a dirt cheap Intel soft-modem that worked as an FXO port for asterisk (connected telephone line to computer). I think it's discontinued, but never hurts to search. it should be mentioned on the various asterisk sites.
Tested it on my fixed line today. The software picks up the phone but doesn't seem to respond to the key pressed. Also, can I use an infrared modem (named as 'Standard Modem over IR link' by Windows) simulated by a Nokia 6101 handphone for this purpose? |
multiport, as in, multiple phone lines.
many businesses would use PRI cards to route 24 voice channels (equivalent to phone lines) into the pbx at a time. smaller businesses can use 4 or 8 port FXO cards to connect standard analog phone lines to a pbx. if asterisk isn't responding to key presses, most likely your modem cannot function as an FXO card, or it's not setup properly. You'll have to look at your initialization strings to make sure the voice modem features are enabled.
Btw, in some toll-free 1800 services, there's an option saying 'Press 0 to speak to our customer service officer'. How do I go about implementing this using asterisk? I want something like 'If you hate this system, press 0 to speak to me directly' Thanks for the useful suggestions! |
look at extensions.conf ... this file is where you put all your 'menus'. there's two options for playing back voice prompt files, one doesn't allow interruption, one does.
Actually I was looking for the exact same thing. I too will research Astrix and let you know soon.
My HP laptop has a BroadCom DATA / FAX 56k modem, but not sure if its the "voice" type. I am kinda confused about that. Can anyone clear that? The main reason of doing that was to accept calls, have a Voice Interface and then ask the user to enter commands (numbers) to control any external device connected to my PC. So, right now I'm just on the part of trying to accept the call and answer back. |
Just on DTMF, I'm about to embark on a project with the MT8888 Integrated DTMF Transceiver IC, $5.50 from www.futurlec.com
Here's an extract from the datasheet; From there, DTMF detection and production is all controlled digitally. This little chip has plenty of real life applications
Spency. PIC Micro's - Your mind is the limit PIC's and interfacing with other devices - a PIC Basic Guide @ digital-diy.net |
| Good Electronic Supply's Sites, Everyone Come On In! :P | Electric Rain | General Electronics Chat | 44 | 27th August 2007 11:05 PM |
| Could anyone tell me where I might find a DTMF decoder IC? | Micah | Micro Controllers | 10 | 16th August 2007 12:26 AM |
| siemens mc35i GSM modem interface with my controller | bhimanipankaj | Micro Controllers | 4 | 8th February 2006 08:11 PM |
| Problem with AVR and Modem | icabrera | Micro Controllers | 1 | 21st November 2004 10:24 AM |
| Interfacing a microcontroller with a modem | matt_d82 | General Electronics Chat | 3 | 21st March 2004 02:43 AM |
