| Where are you going to find a high quality 4.7uF non-polarized capacitor? If the volume control is 100k and R2 is 1M then a very good 470nF metalized plastic capacitor can be used and the low frequency response will be the same as now. The same for the output capacitor, use a 0.47uF metalized plastic capacitor. Then the whole preamp will be -6dB down at 3.4Hz and be flat down to about 30Hz.
| VR1 will be incredibly expensive with 0.1% tolerance. | |
| audioguru is right about the capacitors. DO NOT use crappy dielectrics like Z5U and X7R. They are fine for bypass but aren't for audio stage coupling. Speaking of bypass, where is it for this circuit? Also use an np0 or c0g capacitor for C2. Don't trust people selling npo or cog, there is no such thing. Last edited by mneary; 20th April 2007 at 09:39 PM. | |
| A cheap ceramic disc capacitor as a coupling capacitor makes a lousy microphone. If anything bumps it then it makes a noise.
| Circuit Diagram has been changed accordingly.. ![]() But in my view,(need ur guidence) Soundcard output impedence is low and our preamplifier input impedence is enough high. This impedence mismatching will cause the noise.. Am i right!!!. Thanks. | |
| What u say! it's all right and ready for PCB??? | |
| Finally PCb has been completed. Put Suggestions and comments about my PCB and components layout. ![]() ![]() Thanks. | |
| It looks good and it should operate good.
| Finally let us know what frequency response u got? How u find the quality? What software used 4 making nice pcb. | |
| The frequency response of a modern opamp like the TL072 with a voltage gain of only 7 is about 320kHz at low levels and 100kHz at high levels. An old 741 opamp has trouble above only 9kHz. An old LM358 or LM324 has trouble above only 6kHz. The distortion is about only 0.003% up to 2kHz and less than 0.02% up to 20kHz. The old LM358 and LM324 have 3% crossover distortion with a gain of 1 and higher distortion at higher gain.
| Speedometer | Kiko | Micro Controllers | 131 | 29th November 2007 06:33 PM |
| Need some help with a code provided by ATMEL | ikalogic | Micro Controllers | 1 | 23rd January 2007 03:46 PM |
| Looking for HIGH gain microphone preamp circuit. | ken3983 | Electronic Projects Design/Ideas/Reviews | 5 | 5th July 2004 01:16 AM |
| Having problems with pic16f872 | cjgalway1000 | Micro Controllers | 0 | 7th April 2004 03:39 PM |
| Audio Quality | tim_l_012 | General Electronics Chat | 3 | 6th November 2003 11:00 AM |
