Hi.
An electrical joint causes problem during data transmission I have two questions: 1. Why it produces noise in a telephone line while it is twisted enough to make sufficient contact with other wire. 2. Does it causes problem with even power transmission(i.e. transmitting power for home appliances.240V 50-60Hz.) |
(permalink) | ||
After some time, the wires will oxidise and there will be a high resistance contact between them. As the wires move, the resistance may change causing a variable volt drop across the joint, and so the telephone signal will be noisy. Quote:
The joint will get hot, there could be a large volt drop across the joint, but unless the resistance becomes very high, you may not notice the problem. JimB
Experience is directly proportional to the value of the equipment ruined. |
Capacitive coupling, is the answer, the two wires with an insulator between them form a capacitor which can pass AC signals and result in crosstalk.
Wires you want to keep connected for any length of time should be soldered or at least taped to keep them from oxidizing.
| Basic Soldering & Desoldering Guide | ElectroMaster | Electronic Theory | 13 | 3rd October 2007 04:54 PM |
| Help getting rid of flux | markland556 | General Electronics Chat | 30 | 22nd October 2006 12:10 AM |
| Soldering (beginners) | doblenine | Electronic Projects Design/Ideas/Reviews | 2 | 19th January 2005 06:38 AM |
| Newb Questions | duffman | General Electronics Chat | 9 | 17th June 2004 10:15 PM |
