Old 5th April 2007, 01:34 PM   (permalink)
Default A Rainbow LED
Hi all, I have searched the net to no avail. I am after a circuit that will fade through all colours using an RGB LED. I cannot have a PIC Micro controller. I know that I can use op amps in a circuit, but I want it to be simpler... If anyone knows of or has any circuits or circuit ideas, they are greatly appriciated.
Thanks a lot!
mike
mike11298 is offline
Old 5th April 2007, 04:31 PM   (permalink)
Something like this?
http://www.led1.de/shop/index.php?cP...26&language=en
Andy1845c is offline
Old 5th April 2007, 08:04 PM   (permalink)
I don't think there is a better way. Op Amps give the best display (fuller spectrum, a little randomness). One chip (LM324), three capacitors (220 uf), and nine resistors, three transistors (2n3906).
HarveyH42 is offline
Old 6th April 2007, 03:12 AM   (permalink)
Your circuit sounds simpler than mine. Here it is:
Old 6th April 2007, 03:13 AM   (permalink)
hey andy, thanks for the thought but i have to be able to control it
Old 6th April 2007, 03:20 AM   (permalink)
I made some fading LED projects that shine brightly on the ceiling at night.
They use opamps as oscillators and as integrators to make the slow triangle waves.
Each oscillator is at a slightly different frequency from the other two so that the three colours appear randomly and at differing levels which makes every shade of every colour.
Occasionally they are all off making black, and occasionally they make pure white.
audioguru is online now
Old 6th April 2007, 06:46 AM   (permalink)
Sounds really neat. Got a schematic by any chance?
Old 6th April 2007, 07:23 AM   (permalink)
Hi again. Just found this on the net (attached) as you can see, i want to get rid of one of the LED segments, and the extra LED. I assume the quick alteration will work fine, and i also assume the extra LED is just acting as a diode/power indicator. Do you guys agree? Is there anything i've missed? Thanks a lot.
Old 6th April 2007, 03:40 PM   (permalink)
Hi Mike,
My fading LEDs circuit is similar to the one Bill Bowden made on his website called Fading Red Eyes or something like that.
The circuit you posted is unusual because the Extra LED #5 is used as a voltage regulator for the 74HC14 IC. It should be a green, white or blue LED because a red LED has a voltage that is too low to power a 74HC14 IC.
The L339 IC has a minimum output current of only 6mA so if you get an LM339 at its minimum then the LEDs will be fairly dim.
Old 6th April 2007, 05:18 PM   (permalink)
I just caught a link in the micro section, to this:
http://www.petesworld.demon.co.uk/ho...0colour%20wash
Perhaps that is what you were looking for?
BeeBop is online now
Old 6th April 2007, 05:56 PM   (permalink)
Those do not seem to offer any control over the RGB...
There seems to be an in built chip and oscillator.
Bharath Bhushan Lohray.
M.Sc. Electronics.
lord loh. is offline
Old 6th April 2007, 05:58 PM   (permalink)
sorry... i WAS QUOTING
M.Sc. Electronics.
Old 7th April 2007, 07:35 AM   (permalink)
yeah, im after somthing that i can completely controll, but no PIC
Old 7th April 2007, 07:37 AM   (permalink)
Auidoguru,
Hmmm thanks. I didnt realize that. It doesnt sound too fantastic... should I stick with my original? (posted earlier)
Old 7th April 2007, 12:59 PM   (permalink)
I attached a PDF of Bill Bowdens fading circuit. It explains how it works, and things you can change. You will need 6 op amps, if you want to control each RGB color individually, or to reduce part count and board size you can cross-fade two colors. I used 220 uf capacitors for a much longer fade.
It doesn't take long to breadboard, parts aren't too critical. So you can use what's on hand or experiment. You only need one voltage divider, and can be shared with the other 1 or 2 colors. Adding a pot to control the rate isn't needed, component tolerances will give you a slightly different frequency for every triangle generator, but might be nice if you want to make one color dominate.
36 LED Sequencer HELP NEEDED aquaviventi General Electronics Chat 6 20th August 2007 02:28 AM
Request for help on an LED bar graph circuit by an electronics noob. ThrowingChicken Electronic Projects Design/Ideas/Reviews 38 14th April 2007 02:09 AM
Flashing a LED with Mouse Gayan Soyza Electronic Projects 12 28th March 2007 11:54 PM
Accessing EEPROM Clayton Micro Controllers 15 23rd March 2007 04:00 AM
Pspice LED Error kogula14 Electronic Projects Design/Ideas/Reviews 3 14th March 2007 05:03 AM
