Old 3rd April 2007, 07:23 AM   #1
Arrow 5 Questions on NE555
I’m using NE555 in ASTABLE mode. I want to turn an LED on & off continuously with these requirements.
ON time 3 Seconds
OFF time 1 Second
(LED will turn ON 3S & OFF in 1S)
These are the formulas I used to calculate my R1 & R2. C1 I used 10uF.
Mark time (output high): Tm = 0.7 × (R1 + R2) × C1
Space time (output low): Ts = 0.7 × R2 × C1
After calculating I got this values.
R1=285 Kohms
R2=142 Kohms
Questions
1) Is my values correct?
The duty cycle is the proportion of the complete cycle for which the output is high (the mark time).
The duty cycle formula is given by D = Tm / (Tm+Ts).
2) What is the different between Duty cycle and the Mark time? These both are depending on ON time?
3) What is the meaning of 90% duty cycle? Is that the mark time is ON for 90% & the other 10% is space time?
4) In my earlier example the duty cycle is 0.75.Is that means the mark time is 0.75? But I calculate the Mark time as 3 seconds.
5) If I want to turn ON an LED bulb for a calculated time and OFF for another time do I need to consider about Duty Cycle? Or can I ignore that.
Suraj143 is offline
Old 3rd April 2007, 09:46 AM   #2
Mark time = output high = ON time
ur duty cycle is 75 % Because the full cycle is 4 second, 3 second on time, 3/4 x 100 % = 75 %
bananasiong
bananasiong is offline
Old 3rd April 2007, 02:42 PM   #3
The values you have calculated look OK, but you may get some inaccuracy because of the leakage through the electrolytic cap which makes it discharge slightly faster than you expect.
dch222 is offline
Old 3rd April 2007, 03:24 PM   #4
Electrolytic capacitors have a very wide range in their value. Your 10uF capacitor might be 8uF to 15uF.
audioguru is offline
Old 3rd April 2007, 05:57 PM   #5
http://www.doctronics.co.uk/programs/ic_555.exe
This will save much of ur time..
Ayne is offline
ne555, questions
First post - two questions :D ComputerPsi General Electronics Chat 7 30th May 2007 04:19 AM
Need vox to reset ne555 on no sound help nickcol Electronic Projects Design/Ideas/Reviews 5 13th November 2006 01:11 AM
Questions about relays... nerosrevenge General Electronics Chat 1 4th November 2004 09:31 PM
How do i use the NE555 Chip?? radialspel General Electronics Chat 4 9th April 2004 11:02 AM
Electronics Pre-Test questions Mike_07 General Electronics Chat 0 13th November 2003 03:22 AM
