| | (permalink) | |||
I do agree with your comment: Quote:
However, while reviewing other cases yesterday I noticed that the Silverstone TJ-09 (which I might purchase) does not use the plastic mounting brackets. I'll have to confirm this for sure, but it looks as though the peripheral drives mount flush (metal to metal) with the metal cage. Based on the comments I've received, this seems to be a good practice for ensuring a good safety ground. A comment posted on another site has made me change my mind about using conductive copper tape to improve the ground of the DVD Drive: Quote:
![]() Thank you for your comments Last edited by Peach; 7th April 2007 at 03:02 PM. | ||||
| Ahh, sorry about that, I wasn't paying close enough attention to the plastic mounting brackets comment. Every drive of any kind I have ever used has metal to metal contact between the device case and system case, I was just mentally assuming this existed, the picture helps a lot. I wish more people used images. I've never seen plastic mounting brackets like that before, and I'd immediately throw them out the window if I did =)
__________________ "Because I be what I be. I would tell you what you want to know if I could, mum, but I be a cat, and no cat anywhere ever gave anyone a straight answer, har har." Last edited by Sceadwian; 8th April 2007 at 01:35 AM. | |
BTW, I have sent Antec an Email asking about the use of the Plastic Mounting Brackets and relating my failed mobo experience. I'm just curious to see what they say. I noticed that even their most expensive case uses these. The only reason I can think of why they would use the plastic brackets is for quieter operation. A solid safety ground would seem more important. Thanks again for your very informative comments and help. | ||
| Good luck with your future system, you could also create a grounding point on the outside of your case to touch before you touch any other part of the system. Most cases are painted or otherwise insulated from the chasis material itself, but you could put in some kind of direct metal contact to the chasis that you just get into the habbit of touching before you do anything with the computer, or otherwise make the immediate environement less prone to static build up (conductive mat or more grounding points)
__________________ "Because I be what I be. I would tell you what you want to know if I could, mum, but I be a cat, and no cat anywhere ever gave anyone a straight answer, har har." Last edited by Sceadwian; 8th April 2007 at 02:06 AM. | |
I currently have a 3M Velostat electrically conductive mat (4'x6') in front of my desk and PC. The mat is connected (via a cord) to the metal screw on my grounded 3-prong receptacal. The mat also has attached to it a snap-on cord with a wrist strap that I have attached to the top of my desk that I touch before touching my PC. I also use this grounded wrist strap when inside my PC. ![]() Whew!...now for my Conductive Safety Shoes | ||
| You have all that and you still got an arc to the PC? or is the mat new? I've never used a ground strap in my life, all you have to do is touch the PC case itself and you're instantly grounded.. Invest in a humidifier for the area or something! If after touching a grounded object for a few seconds you're still able to produce an arc a short timer later something weird is going on.
However, my desk and PC have been in this exact same location for 10+ years and I never had an issue with ESD and so I was not in the habit of touching the metal on my case prior to these latest events. I've had 4 different PCs I've built in this same location and never a problem until building the new system I have now. So that's why the ESD/or whatever it was, seemed to be isolated to something in the new PC rather than my residential electrical system (not that something could not have changed with my electrical system...but it has been thoroughly checked twice). Come to think about it, I've built/repaired a couple dozen other computers for others in this same space without ever experiencing an ESD issue. Seems like my problems has to be the Plastic Mounting Brackets or PSU. ??? My PC Specs: ASUS M2N-E AMD 64 X2-5200+ 2GB Corsair XMS PC2-6400 GeForce 7900gt Ko Last edited by Peach; 9th April 2007 at 02:28 PM. | ||
| TC4427A (H-bridge), Output current, Long term | Halo | Electronic Projects Design/Ideas/Reviews | 1 | 6th March 2007 07:58 PM |
| K8055 USB Interface Visual Basic Help | Sudonon | General Electronics Chat | 6 | 11th September 2006 01:25 AM |
| Need Someone Realy Good At Computers..... REAL good | PapaSmurf | Chit-Chat | 16 | 3rd May 2006 11:31 PM |
| EPE magazine - may 2001 issue - PIC graphics LCD scope | evandude | General Electronics Chat | 4 | 12th December 2004 06:43 PM |
| long resistors | spuffock | General Electronics Chat | 7 | 15th March 2004 10:24 PM |
