Old 31st March 2007, 11:43 PM   (permalink)
Default AD558 output boost
I picked up a couple DAC chips earlier today at a surplus store in town that had them for like 4 bucks cheaper than digikey. I was browsing the PDF and noticed since the feedback to the internal buffer amp is available on one of the pins you can use a current boost transistor to increase output current, they use the venerable 2n2222 as an example and I do have a few around if I want to use one, but I was wondering if I could just substitute say one of the 4 amp mosfets I have instead to use it as basically a digital variable linear voltage regulator. Bellow is a capture of the part of the PDF that shows the boost setup and a link to the full PDF. It doesn't contain much information aside from the simple example.
http://www.analog.com/UploadedFiles/...=ad558jn&la=en
straight answer, har har."
Old 1st April 2007, 02:11 AM   (permalink)
I would expect the AD558 to be able to overcome the threshold voltage of a logic driven MOSFET, if Vcc is high enough. I wouldn't expect an ordinary MOSFET to work quite as well.
mneary is offline   Reply With Quote
Old 1st April 2007, 03:11 AM   (permalink)
The only power FET's I have are IRF510's. I'm concerned about oscilation problems since a FET's active regioin (especially a logic fet) is so small, and non linear.
Old 1st April 2007, 11:06 AM   (permalink)
It doesn't matter, I've used power MOSFETs in their non-linear region before without any problems but you need to ensure the gate is sufficiently above the source or the voltage drop will be enourmous.
Screen name: Aloone_Jonez
Hero999 is online now   Reply With Quote
Old 1st April 2007, 05:20 PM   (permalink)
The DAC is 10 volts out, should be plenty.
Old 1st April 2007, 05:30 PM   (permalink)
But if you're using a source follower, then the maximum output will be about 5V depending on what current you're drawing. This is why you need a voltage doubler and op-amp to to shift the voltage up above the supply to get a decient dropout voltage.
Old 1st April 2007, 05:46 PM   (permalink)
I thought the opamp on the DAC is what did the voltage following, simply connecting the sense/gain pins to the point where you want the voltage to follow and the VOUT should go from any voltage from 0-VCC in order to get the sense voltage to coincide with the DAC's currently set value?
Old 1st April 2007, 07:14 PM   (permalink)
I don't think you understand what I'm saying, I might not be explaining it very well.
With an emitter follower you loose 0.6V + the saturation losses, with a MOSFET you loose the threshold voltage + the conduction losses. Since the threshold voltage on a MOSFET is so high you'll need to power your circuit from >15V to get 10V at any reasonable current. To get round this you use a smaller power supply for the gate driver circuitry.
Old 1st April 2007, 07:58 PM   (permalink)
Never mind Hero, sorry I wrote that post in a hurry I realized what was wrong with it right after I left =)
Discrete Pulse width Modulator... Rajagopal87 General Electronics Chat 8 16th August 2006 05:25 AM
uuffff how doess this stupid ting work lol cyprio7 General Electronics Chat 7 9th October 2005 06:55 PM
I am not getting ripple voltage at the output dar2525 General Electronics Chat 3 14th July 2005 02:20 PM
Function Generator output driver evandude General Electronics Chat 6 31st January 2005 07:49 PM
Effects stephenpic Micro Controllers 6 19th January 2004 11:57 AM
