Old 30th March 2007, 11:24 PM   (permalink)
Question Please explain
Can somebody please tell me the difference between a Mosfet and a Mosfet Driver. And what sort of driver do I need to use between a radio control receiver output (pwm) and a Power Mosfet to drive a small motor?
Thanks to everybody.
Rog.
Rog.
If it comes down slower than it went up, it's a landing.
Vice versa, it could be a problem.
bristol188 is offline
Old 30th March 2007, 11:40 PM   (permalink)
A MOSFET is a type of transistor, a MOSFET driver is a circuit which drives power in and out of the a MOSFET's gate large capacitance to enable it to switch on and off very quickly.
Screen name: Aloone_Jonez
Hero999 is offline
Old 31st March 2007, 02:48 AM   (permalink)
You don't just need a driver, you need a decoder. Servo signals are 1.5ms center and 1ms and 2ms to either extreme repeated approximately 50 times per second. Best case scenario (2ms signal) this will only give you a 10% duty cycle, worst case (1ms signal) it will give you a 2.5% duty cycle, and the frequency isn't fixed (it's slightly variable depending on all of the other channels aggregate duty cycle plus the framing pulse) This is not a signal that can be used to drive a Mosfet directly.
You either need to use a pulse stretcher which coverts that short servo pulse into a simple PWM frequency (0-100% duty cycle at extremes) or use a micro controller to read the pulse length and drive the mosfet for you. Mosfet drivers usually have two purposes, one is for driving a high side mosfet because voltages greater than VCC are required to get a high side FET to switch on so a charge pump is usually used. The other is if you want to minimize FET transition losses by creating very sharp edged switching transients from perhaps a softer logic edge to avoid operating in the FETS linear range, which creates heat. Logic levels FETS are very common and for common voltages can be driven directly from the I/O line of a micro controller or from discrete logic.
straight answer, har har."
Sceadwian is offline
Old 31st March 2007, 04:33 AM   (permalink)
Here’s an example of a FET drive circuit;
Click here to watch this circuit in action
Notice that the two transistors act like a push-pull switch, driving the FET on and off. This is required for FET's driving large currents, not all circuits need this, but as the example shows above, it can also be used to drive FET's with logic voltages/signals (like a 5V PWM)
To control the speed of the motor, simply change the PWM duty cycle. PWM (Pulse wave modulation) is a simple way of saying on timeff time. So if you had a 50% duty cycle, the period of on time would be 50% and off time would be 50%. 100% = 100% on 0% off
The frequency of these cycles would need to be considered, and a quick check of the datasheet of your FET will let you know how fast your PWM needs to be.
Spency.
PIC Micro's - Your mind is the limit
PIC's and interfacing with other devices - a PIC Basic Guide @ digital-diy.net
gramo is offline
Old 31st March 2007, 11:29 PM   (permalink)
Thank you all for that I'm fully explained. I mean that sincerly. (bows head and retrets backward)
Roger
Rog.
Old 28th August 2007, 03:46 AM   (permalink)
For the newbie trying to understand schematics could you tell where the positive and negative of the 12 volt and 5 volt TTL go to please.
firewater is offline
can anyone explain how to control a servo motor?? TheMaccabee Robotics Chat 4 4th April 2007 02:55 AM
Can someone explain how this circuit demodulates ? aidob General Electronics Chat 19 27th November 2006 01:16 AM
Can someone explain isolated and non-isolated circuits? lompa Micro Controllers 7 31st October 2005 04:34 PM
Can someone explain line buffers stcogolin Micro Controllers 2 2nd December 2003 02:21 PM
Could someone explain this? hantto General Electronics Chat 2 6th January 2003 04:28 PM
