Trying to fix my car central locking remote, and discovered that all four pins on one side of a surface mount IC have come loose. Is there an easy (non-soldering) way to fix this ? I'm not confident I could re-solder them without toasting the chip. Otherwise, any tips for re-soldering without melting it ? | |
| | #2 | ||
__________________ Inside every little problem, is a big problem trying to get out. | |||
Try to find the cause of the problem. Make sure (really sure) that everything is clean. Use an excess of flux and fairly small soldering tip. It's not necessary to use a tip that's smaller than the contacts. Try first on something that doesn't matter, to give you confidence. You'll be OK. | |
For reworking stuff like this flux is your best friend (just don't make the mistake of using plumbers flux)
| | #5 | |
| | #6 |
Are there solder pads underneath? Not all pins have to be connected. A quick picture wouldn't hurt (digital cameras are a godsend)
| | #7 |
If half of the pins aren't connected, it would be a good idea to determine why. Is it by design? Manufacturing defect? Did it ever work? Did it overheat? Did moisture dissolve some of the leads?
| | #8 |
If you have a pic-em-yourself junkyard I would visit it to see if I could find a replacement. You could at least look at similar units to see if the pins were supposed to be connected. If the chip is visible without removing covers or screws (out in the open) you could visit a dealership and ask to see a replacement part. Most partsmen are up to that sort of thing if they are not in the middle of a rush. Take yous along so you can compare them.
__________________ Please post questions to the forums. PM's are for personal communication. BCHS/3v0's Tutorials Junebug USB PIC programmer kit., USB Bit Whacker, The 15 Minute Printed Circuit Board! (+drill time) Last edited by 3v0; 25th March 2007 at 08:57 PM. | |
| | #9 |
just a question for the experts. do those cold solder irons work at all ? i was going to buy one at RS but the guy said they dont work for component level work.
| | #10 |
I have one, it's good for me for quick and dirty jobs usually just desoldering something real fast as I don't have a location to set up a proper soldering station as yet. There's a lot of arcing at the tip and the power output is pretty low, but at the very least it will do in a pinch as a quick and dirty task light (it has a white LED in front) and if you touch wires to either side of the tip you get a quick and dirty access to the batteries (6 volt power supply) I use it to test small motors. I would not recommend it for a hobbyist for a primary soldering tool. You'd be better off spending the 20 bucks on a cheap soldering iron. There's supposed to be a cold solder plus which uses one more AA battery, which actually increases the power output quiet a bit. On a fresh set of batteries it will generate 60 watts, but keep in mind it applies a voltage to what it's touched to, the combination of the current flowing through the work material and the tip itself generate the heat. I wouldn't recommend using it on sensative IC's they say the tip is made out of a patented substance, but it's really just graphite with some kind of binder (pencil lead basically) I told my fiance I just couldn't see myself spending 20 bucks on it, but it'd make a good gift. I got one that Christmas =) Good gift, poor intentional purchase
__________________ "Because I be what I be. I would tell you what you want to know if I could, mum, but I be a cat, and no cat anywhere ever gave anyone a straight answer, har har." Last edited by Sceadwian; 26th March 2007 at 06:25 AM. | |
| mount, repair, surface |
| surface mount soldering techniques | Richard Principal | General Electronics Chat | 5 | 12th November 2006 05:44 AM |
| replaceing surface mount with normal size capacitor | mikee55 | Electronic Projects Design/Ideas/Reviews | 17 | 22nd January 2006 11:04 PM |
| surface mount type chips | charliec | General Electronics Chat | 5 | 23rd March 2005 10:16 AM |
| 16F84A surface mount | Johnson777717 | Micro Controllers | 4 | 28th June 2004 06:26 AM |
| Unknown Surface Mount Device | CapnCavey | Datasheet/Parts Requests | 6 | 13th February 2004 10:06 PM |
