Old 23rd March 2007, 04:31 PM   (permalink)
Default PIC beginner
OK I have a project I would like to do that would require a small PIC. (limited space). I just had some general questions about PIC's
1. Is Microchip the sole maker of "PICs" because its patented and the name is copyrighted?
2. If I find a PIC programmer can I assume it works with all PIC's of the right pin numbers? Or do I need to look at brands?(from question1).
3. Where can I find a cheap, low parts count serial programmer for the 8-pin PICs. I have googled it for 2 hours now with no luck. I would prefer to be able to use software for the programmer that uses C or C++.
If you guys know of any site that would help out please mention it. Thanks.
Ambient is offline
Old 23rd March 2007, 04:46 PM   (permalink)
Yes. There are other manufacturers out there that make similar microcontrollers, like Atmel, but PIC is a Microchip-only brand name.
Any PIC programmer you find should ideally come with a list of the PICs that it supports. Quite often, the main limiting factor is the software - if the software is outdated, it won't support the newest PICs. MOST programmers will handle most of the "usual" PICs that most hobbyists will be using.
The JDM serial programmer is a simple, low parts-count programmer. There are a bunch of different programming software packages that support it, like IC-Prog, WinPIC800, etc. It's so popular, I don't see how you could have missed it with a google search...
However, it does have some serious limitations which I don't feel like rehashing again, but you can find more information if you search the forums. I'm sure Nigel will be here any minute to tell you how bad they are
EEgeek.net
evandude is offline
Old 23rd March 2007, 05:10 PM   (permalink)
"I'm sure Nigel will be here any minute to tell you how bad they are"
lol.
Thanks for the info. I was hoping to find a programmer that could work with the MPLAB IDE software from Microchip, as it is current and has a C compiler. That may be why I missed the JDM one.
The end product of this project is going to be a user-programmable E-trigger for a paint ball marker. I am dissapointed with the quality of the Tippmann E-Trigger and upgrade boards are close to $100! If anyone is interested I will toss in the schematics for the finished design. Just PM me. I am in my senior year for Electrical Engineering so I will not finish this for at least 3 months.
Due to size limitations and only a few outputs and inputs needed (2 input pins, 2 output pins) and the fact that I will be doing mostly timing operations (in millisecond scale) I will try to use the 8-bit PIC's. I could do the project with the Arduino boards, but those require an external clock and are kinda overkill for the project. Would be a lot easier though, as I know how to program for those.
Ambient is offline
Old 23rd March 2007, 05:31 PM   (permalink)
Then u should use ICD2(In circuit Debuger).....
http://www.electro-tech-online.com/m...d2-review.html
Ayne is offline
Old 23rd March 2007, 06:13 PM   (permalink)
I did an electronic paintball marker control board a long time ago, for my 'spydercocker':
http://www.eegeek.net/paintball/spydercocker/
Never got around to really properly finishing it, or documenting the board, but if you're interested perhaps I can dig something up.
As far as MPLAB compatibility goes, well, you're quite limited there. If MPLAB compatibility is really important to you then you should see if your department at school has any microchip-branded programmers you could borrow (my department had a bunch), or else look into building or buying an ICD2 clone. The microchip PICKit2 is another possibility (they're like $35 I think) but I haven't heard the best things about them.
EEgeek.net
evandude is offline
Old 23rd March 2007, 07:05 PM   (permalink)
I have been looking at the ICD2. Looks like it will do the trick. Unless those limitations rear their head. I will search the forums for posts about them.
Thanks for the info man. Looks like a cool project. I will let you know what happens with mine. I plan on making user settable options similar to the Tippmann W.A.S. board, but without that annoying full-auto defect they have with many of their boards.
Ambient is offline
Old 23rd March 2007, 07:49 PM   (permalink)
anyone have any issues with this one?
http://www.stolz.de.be/
I am having problems searching the forums for ICD2 limitations because there are so many posts about ICD2's.
Ambient is offline
Old 23rd March 2007, 09:24 PM   (permalink)
Why are you searching for ICD2 limitations? JDM's have limitations, PICKit2's seem to have some issues, but as for ICD2's, if anything they're the best bet!
There's a forum member here who sells serial ICD2's over at http://www.blueroomelectronics.com/inchworm.htm
If you want a USB model and don't mind building one, try icd2clone.com for designs, or if you'd rather buy one check out ebay where chinese-made icd2 clones are usually all over the place.
EEgeek.net
evandude is offline
Old 23rd March 2007, 10:11 PM   (permalink)
Oh ok. You were saying the JDM programmer had limitations then. Thanks.
Ambient is offline
Old 24th March 2007, 02:36 AM   (permalink)
Yet to have an issue with JDM's, but theres so many to choose from out there, i use the following one
Costs $49 australian
Spency.
PIC Micro's - Your mind is the limit
PIC's and interfacing with other devices - a PIC Basic Guide @ digital-diy.net
gramo is offline
Old 24th March 2007, 06:19 AM   (permalink)
If you will be build PIC project, I have one site that have many project for your development.
PIC project and Microcontroller board.
first_mcs is offline
interfacing PIC to 4511 and ICs mikedf Micro Controllers 2 1st March 2007 07:04 AM
PIC Project advice - doubling frequency coze Micro Controllers 8 26th February 2007 08:05 PM
Most Common and Best PIC? LiquidOrb24 Micro Controllers 13 12th February 2007 03:42 AM
Questions from a beginner in electronics... Shocks McTool General Electronics Chat 8 21st November 2005 03:01 AM
Newcomers, please read! (PIC regarded) Upd. 0xD Jay.slovak Micro Controllers 0 17th April 2005 02:05 PM
