| New Member | Hi all: i want to build a pulse generator using NE564, and the frequency of the pulse is from about 500KHz to 10MHz, could you tell how to use the NE564 as a pulse generator? Thanks |
| Experienced Member | hi, Download the datasheet from www.datasheetarchive.com Example of freq multiplier. Eric EDIT: datasheet attachment, Page 9 Last edited by ericgibbs; 7th July 2008 at 11:19 AM. |
| New Member | Eric, thanks very much! but i couldn't find the datasheet i want, can you help me? Last edited by hitwaterfish; 21st March 2007 at 03:29 PM. |
| Experienced Member | He's attached the datasheet. Anyway don't be lazy, Google knows. http://www.google.com/search?client=...utf-8&oe=utf-8 |
| New Member | Eric,Hero999, Thanks very much. I am now dealing with the circuit but the output frequency do not change when I change the input frequency. And the output frequency is about 10MHz. (When I change the value of Co, the output frequency will change.) How can I change the output freq with changing input signal. I used the circuit of Figure 12 in the datasheet(NE564). waterfish |
| Experienced Member | Quote:
| New Member | For test, I just connected pin 9 to pin 3 directly. So N=1, the output frequency would be equal to input frequency. But even I removed the input signal, there was also output signal as I mentioned before. |
| Experienced Member | hi, Insert a divider ic as shown on fig12. The Vco= f = N [divider] * fT[ the osc input freq] If you use say, use parallel load dividers, you can set the N value being loaded into the divider using bit switches or bin/bcd switches. A HEF4059B programmable divide by N counter would be a suitable ic for a final product. [you could use a simple divider to experiment] Eric |
| New Member | Hi Eric, I used a 74HC4060 as the divider, but the problem was not solved. I found that the output frequency only changed when I changed the value of Co. waterfish |
| Experienced Member | hi, Im puzzled why the cct in Fig12 is not operating in way its described. As I havn't got a NE564 on the shelf I cannot duplicate your setup. Looking on the web, google, there are lots of application notes on the NE564. These may suggest a cure. I'll keep looking, will come back if any succes. Eric
__________________ Eric "Good enough is Perfect" PIC tutorials: Gramo's: www.digital-diy.net/ Bill's: www.blueroomelectronics.com/ |
This part is a phase locked loop (PLL). If you don't have experience with PLLs, I'm not surprised that you are having difficulty. You are probably better off leaving out the frequency divider to start with. As the divider ratio N goes up, the loop gain goes down, and lock is more difficult to obtain. I'm not sure how high N can be and still have the part lock. Do you know that, if you set the VCO free-running frequency to F, and the divider ratio to N, that the input frequency must be F/N? What are you using as a signal source? And why do you want to use a PLL to generate your pulses? | |
| Experienced Member | hi Ron, Have you had the opportunity to look at the HEF4059B as a suitable divider for the NE564.. I have used the HEF4046 in the past for PLL work, never played with NE564 device. Eric
| New Member | Quote:
I am now building a micro-EDM pulse generator. It needs a very short pulse width. I have got some high speed MOSFETs and MOSFET drivers recently. I want to test how high the frequency can be. So I need the signal source. I have use the LM567 before but I cann't use it here because it is not able to make the high frequency pulse. I have been looking for a efficient and low-cost way to build the signal source because I just want to do some experiment. I am not familiar with the NE564. I thought if I set the diveder ratio to N and the input frequency to F, the output frequcney would be N*F. So I could get different output frequencies. As you said, this way wouldn't work. Maybe I should choose some other way. Thanks for the advice. Thanks all. | |
| Problem measuring pulse width - 12F683 TMR1, 8MHz | jess | Micro Controllers | 18 | 5th February 2007 10:00 AM |
| pulse on, pulse off latching switch | b1mmuo27 | Electronic Projects Design/Ideas/Reviews | 15 | 23rd November 2005 01:18 AM |
| Fuel injector pulse detector | brjones | Electronic Projects Design/Ideas/Reviews | 3 | 31st August 2004 08:07 PM |
| Pulse Width Calculation | waqar | Micro Controllers | 1 | 25th June 2003 11:53 AM |
| using 8051 as pulse counter | waqar | Electronic Projects Design/Ideas/Reviews | 0 | 13th March 2003 04:06 PM |
