+ Reply to Thread
Results 1 to 7 of 7
Thread: Capacitor ?
  1. #1
    1Steveo Newbie
    Join Date
    Jan 2004
    Posts
    114
    Default Capacitor ?
    Is there any reason I should not use a Photo Flash Capacitor to replace a Electrolytic. Its part of the TV power supply ?
  2. #2
    Join Date
    Nov 2003
    Location
    Derbyshire, UK
    Posts
    29,769
    It doesn't sound a very good idea! - but you don't give many details for us to base a judgement on. Exactly which capacitor in what sort of power supply is it?.
  3. #3
    1Steveo Newbie
    Join Date
    Jan 2004
    Posts
    114
    Sorry I looked at the cap, and thought it was deformed! But its ok! The cap is part of the switch-mode power supply. The cap is 270uF 200 volts , but going through my junk The only thing I had close was a photo flash cap rated at 300 volts. I was just thinking that the Photo Flash might of worked
  4. #4
    Keruskerfuerst Newbie
    Join Date
    Feb 2007
    Posts
    11
    You should use a switch mode capacitor.
    Lower |Z| at high frequency.
  5. #5
    Sceadwian Excellent Sceadwian Excellent Sceadwian Excellent Sceadwian Excellent Sceadwian Excellent Sceadwian Excellent Sceadwian Excellent
    Join Date
    Oct 2006
    Location
    Rochester, NY U.S.
    Posts
    9,823
    Blog Entries
    1
    Photoflash caps are electrolytics. But they're not usually rated for continuous duty. I'm not sure if you can compare the capacitance and voltage rating on the package as being equivalent to a general purpose electrolytic. Probably not a good thing to try.
    straight answer, har har."
  6. #6
    Hero999 Excellent Hero999 Excellent Hero999 Excellent Hero999 Excellent Hero999 Excellent Hero999 Excellent Hero999 Excellent Hero999 Excellent Hero999 Excellent Hero999 Excellent
    Join Date
    Apr 2006
    Location
    England
    Posts
    13,035
    I wouldn't think there would be a problem, providing the capacitor has a low enough ESR it'll be fine.
    if I know the answer.
  7. #7
    Join Date
    Oct 2006
    Location
    Rochester, NY U.S.
    Posts
    9,823
    Blog Entries
    1
    I know the exact model number of photo flash I have and they don't even list a ESR There's a reason for that, they're produced in bulk and cheaply with wide variances to reduce cost, so the individual device to be used would have to be tested in order to determine if it were okay for use under anything but short pulses infrequently. Even a badly manufactored capacitor is going to last a pretty long time when used at the rate that a disposable camera flash is. I've never taken any apart (they're expensive obviously) so I don't know what kind of capacitors higher end cameras use.
+ Reply to Thread
  1. Major Help Needed Please: Peltier and 2 channel fan controller needed :S
    By MR Spade in forum General Electronics Chat
    Latest: 23rd November 2007, 03:10 PM
  2. Capacitor discharge speed
    By Jo-W in forum General Electronics Chat
    Latest: 27th January 2007, 02:58 PM
  3. Working Of Capacitor
    By babar.khan in forum General Electronics Chat
    Latest: 28th December 2006, 09:08 PM
  4. Superregen (a partial solution?)
    By mstechca in forum Electronic Projects Design/Ideas/Reviews
    Latest: 17th May 2006, 03:33 AM
  5. Break through Capacitor Project
    By Rand in forum Electronic Projects Design/Ideas/Reviews
    Latest: 29th July 2004, 07:46 AM
Tags for this Thread
