Old 11th March 2007, 07:20 AM   (permalink)
Default Question regarding an external xtal…
The attachment contains part of a schematic that contains a MCU that has an external xtal. If someone has the time, can you explain how the values of the two parallel capacitors are determined?
mbu is offline
Old 11th March 2007, 07:26 AM   (permalink)
They should be both 22pF, its in the PIC's datasheet
Spency.
PIC Micro's - Your mind is the limit
PIC's and interfacing with other devices - a PIC Basic Guide @ digital-diy.net
gramo is offline
Old 11th March 2007, 07:32 AM   (permalink)
For better acuracy and sability, you could use ceramic resonators (they have the capictors built-in)
Heres a list of different ones available through Futurlec
http://www.futurlec.com/ICCrystalsResonators.shtml
Spency.
gramo is offline
The middle Pin is the Earth for the capacitors that are internally connected
Spency.
gramo is offline
Old 11th March 2007, 07:47 AM   (permalink)
gramo,
Thanks for the help!
Will a ceramic resonator be accurate enough - I'm using it for an electric motor tachometer? I would like the tachometer to be as accurate as I can make it.
I have a FOXLF100-20 oscillator on hand – will it be okay?
http://foxonline.com/LFSERIESxytal49u.htm
mbu is offline
Old 11th March 2007, 09:40 AM   (permalink)
Gramo, ceramic resonators are less accurate and stable than crystals, not more. The crystal will work just fine. If you need to fine tune the exact frequency of the crystal you can use trimmer caps, but calibrating the whole setup can be a bit finacky.
straight answer, har har."
Sceadwian is offline
Old 11th March 2007, 09:59 AM   (permalink)
Yes, crystals are FAR more accurate and stable than ceramic resonators, the capacitors used on the crystal are very non-critical - anything from 10pF to 47pF usually works fine.
Old 11th March 2007, 10:08 AM   (permalink)
Thanks everyone for the help!
mbu is offline
Old 11th March 2007, 10:26 AM   (permalink)
Sorry guys, I've been mislead by someone else then
Spency.
gramo is offline
Old 11th March 2007, 11:00 AM   (permalink)
Why do people use ceramic resonators then?
They certainly aren't much cheaper than crystals so why bother?
Screen name: Aloone_Jonez
Hero999 is offline
Old 11th March 2007, 11:09 AM   (permalink)
Might just be ease of use.. 3 components in one.
Found a bit of info on the two here
http://www.maxim-ic.com/appnotes.cfm/an_pk/2154
This site has some info on ceramic resonators as well
http://hem.passagen.se/communication/ceramic.html
A quote from the above site
The ceramic resonator is often used instead of crystal because of it's lower price. The frequency accuracy is not as good as a crystal but in many application the accuracy is not critical.
Spency.
gramo is offline
Old 11th March 2007, 11:20 AM   (permalink)
But they are cheaper (certainly in production quantities) - and for many applications the extra accuracy of a crystal isn't required. Personally I've never bought one, but I have used them occasionally, taking them out of old TV's - it saves you looking out a couple of small capacitors!.
Basic Transmission question CamNuge General Electronics Chat 2 8th March 2006 11:08 PM
Question on 3-phase power Kurupt General Electronics Chat 1 8th January 2005 07:12 AM
High speed data logging question cubdh23 Micro Controllers 3 19th August 2004 12:54 PM
Data Logging question with high speed!!!! cubdh23 General Electronics Chat 4 16th August 2004 07:33 PM
PBX question waqar Electronic Projects Design/Ideas/Reviews 0 30th March 2003 07:21 PM
