Old 10th March 2007, 07:55 PM   (permalink)
Default short pulse ---> long hi signal
Hi all.
This is my first question on your forum. I'm just wondering how will I generate a high signal for 1.5seconds from a short 50mS hi pulse?????
Jason
huttojb is offline
Old 10th March 2007, 08:05 PM   (permalink)
You can use a 555 timer monostable circuit. It's like a single pulse generator. Every time you send a pulse to the input, it generates another pulse that remains high for a certain amount of time. You can Google for the circuit- it's one of the two basic 555 timer circuits.
dknguyen is offline
Old 10th March 2007, 08:07 PM   (permalink)
Sorry, I should of said; I didn't want to use a 555 timer (already thought of this) due to cost, I'm gonna be building 50 - 75 of these so I wanted to keep cost to a minimum. I was just wondering is there any cheap and nasty options??
Jason
huttojb is offline
Old 10th March 2007, 08:49 PM   (permalink)
Build a discrete monostable instead - but it's slightly more complicated, two transistors, five resistors and a capacitor (off the top of my head!).
Nigel Goodwin is online now
Old 10th March 2007, 08:52 PM   (permalink)
I'll search on the internet now, could you have a look (if you have the time) and give me a point in the direction
Jason
huttojb is offline
Old 10th March 2007, 09:10 PM   (permalink)
You can do it with a Hex Schmitt Trigger such as the 40106, 74HC14, etc.
You need 2 resistors, one diode and one capacitor per Schmitt.
Len
ljcox is offline
Old 10th March 2007, 09:15 PM   (permalink)
Here is one way to do it. It is designed for a 10:1 ratio.
You can change the 100k to give you a different ratio.
Change the capacitor for longer or shorter times.
Len
ljcox is offline
I'm looking at 74HC14, but could you explain more, it looks like this wouldn't work??
Jason
huttojb is offline
Old 10th March 2007, 09:16 PM   (permalink)
plus the signal is reversed
huttojb is offline
Old 10th March 2007, 09:18 PM   (permalink)
I just posted a circuit. It does work, I've used it many times.
For example, I used it in a garage door opener. I wanted to make the light stay on for about 2 minutes.
So the delay is started when the up or down button is pressed and remains on for approx 2 min.
Len
ljcox is offline
Old 10th March 2007, 09:19 PM   (permalink)
Use another inverter to invert the output.
Len
ljcox is offline
Old 10th March 2007, 09:23 PM   (permalink)
Could you tell me where the cct is, Is it very expensive to make, don't for get I'm making 50 of these?
Jason
huttojb is offline
Old 10th March 2007, 09:28 PM   (permalink)
Jason
The circuit is 5 posts above.
You could also use the same technique with 556 ICs, but there are only 2 per IC so it is probably more expensive.
Do you have to have a positive trigger and a positive output?
If not, then you obtain 6 circuits per 40106.
Alternatively, as someone wrote, you could use a dual Monostable.
Then you only need one R and one C.
Len
ljcox is offline
Old 10th March 2007, 09:32 PM   (permalink)
I'm using a PIC to send a pulse and I want this cct I'm trying to get to switch a transistor for approx 1.5 seconds.
I got a positive input and I need a positive output.
I've looked at the dual Monostable on the internet and can't find an example to look and see how it works and re-construct on Multisim??
Jason
huttojb is offline
Old 10th March 2007, 09:33 PM   (permalink)
Look at the data sheet of the Mono.
Len
ljcox is offline
The Oscilloscope ElectroMaster Electronic Theory 12 3rd February 2008 02:45 PM
Need help identifying sensor / signal on motorcycle. Phoenix General Electronics Chat 3 7th May 2003 09:32 PM
Yet another LED taillight controller...... NickK Electronic Projects Design/Ideas/Reviews 1 31st March 2003 06:38 PM
using 8051 as pulse counter waqar Electronic Projects Design/Ideas/Reviews 0 13th March 2003 05:06 PM
