has anyone tried the toner transfer method using silicone impregnated paper (sold as "parchment paper" in the baking isle, not to be confused with waxed paper)? I was doing some baking yesterday and the idea hit me that the paper is nice and thin, and would work well for lining up double sided layouts - as it's much more translucent than photo paper. it has a very low surface friction, not as non-stick as teflon but pretty slippery - if the printer can deposit toner on it, the toner should be eager to come off again for something like copper clad that's been burnished with steel wool. the package claims not to use past 450F, so the heat of the iron should be well below that range - I don't know about the heat of the fuser in the printer... since the silicone is part of the paper, rather than a coating applied on top, it shouldn't come off during the ironing process. what are your thoughts?
__________________ If you don't have a planet, what good are gold bars? want to contact me directly? gmail gordonthree check out my project website: http://projects.dimension-x.net Favorite numbers: 09 F9 11 02 9D 74 E3 5B D8 41 56 C5 63 56 88 C0 | |
I've tried it and it didn't work. The paper is too wrinkly and it tends to get baggy when you apply the iron. I couldn't get the toner to form solid traces on the board.
You should try the backing to peel-off labels. temperature and pressure stable.
I bet you can even reuse it a couple of times!
I tried baking parchment, alu foil, various brands of printer paper etc. The problem with the parchment wast that it was too slick. The toner would not stick to it. For a a buck or two a sheet you can get stuff that work without screwing around (Pulsar or P&P Blue). Why mess with it. | |
| | #6 |
I would really like to see someone try something like what this page sells http://www.smallparts.com/products/d...ons/vt-vte.cfm It'd be cheaper than press and peel blue and re-useable.
| | #7 |
Both Pulsar and P&B blue use a layer of another material over the somewhat pitty toner to provide dense traces and pads. Even if then toner sticks enough to transfer, and if you find some way to release the sheet from the toner, it still will not work as well as the commerical products. You can skip the transfer step and mod an old laser printer to print directly on the copper clad. The problem there is that you will have to invest in a laser printer cartridge for the old laser printer. | |
| | #8 | |
Printing directly onto a sheet like you are suggesting is just a balance between toner adhesion during printing, and ease of peeling after ironing, based on how slick the sheet is. I've heard mention of people printing directly onto regular transparency sheets (which are a bit less extreme than teflon) and peeling, but haven't heard any great success stories. As a sidenote, I know everyone always complains about the price of press-n-peel and similar products, but really, it generally costs under $2 a sheet, and when you use it properly, which is easy, (cut out only as much as you need and tape it to a piece of plain paper for printing), there is very little waste, and it works out to something like 2-3 cents per square inch. That's cheaper than the PCB it gets put on, and probably on par with the cost of the etching solution you use to etch it. Yeah, it's a small investment, as you have to buy quite a few sheets at a time, but still...
__________________ EEgeek.net Last edited by evandude; 11th March 2007 at 06:32 AM. | ||
| | #9 |
I'd have to agree with Evan, the price per board is quite low for Pulsar or Press and Peel. Also get the second layer (Pulsar uses green TRF,) because it does work very well. I went from trying to make double sided boards to 'getting everything on one side,' because I could make the traces that much thinner. I think Philba offers a good idea, though, with the label backing, if you really want to spend the time researching alternatives. But then again, if your time is worth anything, then the existing technologies would be the best route to go. | |
| | #10 | |
In any case, if anyone does feel motivated enough to try out some of these suggested transfer methods, I'm sure everyone would be very interested in seeing the results. I'm very happy with press-n-peel, so I don't feel the need to experiment with new methods myself, but that's not to say I wouldn't switch to something else if someone else experimented with it first and found it to be great.
__________________ EEgeek.net | ||
| | #11 |
If you want to go down the cheap route of using something like PTFE or magazine paper then a fine line permanent marker is always useful for filling in any gaps in the toner.
| | #12 | |
Yes, Quote:
| | #13 |
Perhaps you used a cheap and nasty pen. When I use magazine paper it doesn't take that long to fill in the odd gap because there aren't that many.
| | #14 |
So far I'm getting good results with HP premium plus photo paper ... downside is it costs more than pnp blue ... I'll try some of that next ... lowest cost isn't the big objective here, just trying to think of using what I have versus sending out for different stuff ![]() I'm still a firm believer in photolithograpgy, but I needed an alternative method to produce a one-off board, since with my photo setup I produce an entire 4.5x6.5 inch panel at once. From my supplier I pay $2.95 for a 4x6 sheet of 1/16 1oz copper clad plain, or $3.25 for 4.5x6.5 sheet of 1/16 1oz positive acting copper clad.
| | #15 |
The commercial transfer papers work well and are not expensive. Pulsar even has a method to do silk screens. At this point a better board would have plated through holes, and solder masks. Yup, send it out. For me the tools and methods can be as interesting as the actual projects. But at this point the transfer process is, for me, a done deal. Experimenting with it is falls under the same catagory as making my own wire. There seem to be some journey that people have to make by themselves. Maybe this is one of them. | |
| impreg, paper, silicone, toner, transfer |
| PCB toner transfer | Badar | General Electronics Chat | 58 | 16th July 2009 02:40 PM |
| Toner Transfer method question. | HarveyH42 | Chit-Chat | 18 | 4th March 2007 06:16 PM |
| toner paper | nye | Electronic Projects Design/Ideas/Reviews | 8 | 27th October 2006 10:23 PM |
| PCB toner transfer stuff? | Oznog | General Electronics Chat | 5 | 7th March 2006 04:37 PM |
