LED Displays - Common Anode or Common Cathode?
Results 1 to 6 of 6
Reply to Thread
  1. #1
    mbu
    mbu is offline
    Default LED Displays - Common Anode or Common Cathode?
    What are the advantages/disadvantages of a common LED anode display and a common cathode LED display?
    Thanks...
  2. #2
    kchriste
    kchriste is offline
    There is really no advantage from using one or the other.
  3. #3
    Sceadwian
    Sceadwian is offline
    You chose common anode or common cathode based on the LED drivers ability to source or sink current. Most modern chips are effectively symmetrical in their ability to source or sink current so it's not usually an issue. So it's really up to what you're going to drive that particular LED matrix with.
    could mum, but I be a cat and no cat anywhere ever gave anyone a
    straight answer, har har."
  4. #4
    mbu
    mbu is offline
    kchriste and Sceadwian,
    Thanks for the answers - I appreciate it very much!
    Mike
  5. #5
    Oznog
    Oznog is offline
    Quote Originally Posted by Sceadwian
    Actually much more often the driver likes common anode:
    NMOS generally drives much better than PMOS. More current capacity, lower rds-on for a given size and cost.
    Often you have a +12V source and a +5v driver sharing the same ground. That driver can put out 0V/+5v to drive an NMOS gate, but it can't drive a PMOS without additional circuitry.
    But of course it depends on your specific driver. There are certainly instances where common cathode will be called for.
  6. #6
    gramo
    gramo is offline
    Just a few other things to take in consideration with segment displays..
    For multiplexing there are a couple of things to take into account,
    By hooking a single resistor in series with the common, you’re going to put every other LED in reverse bias, eg
    If any LED Segment is on (supplied with +5V for example) there will be a voltage potential above the 220ohm resistor, any other LED Segment not in use will now be in reverse bias (reducing the life of each segment)
    So the correct way to wire them up would be
    Now the reverse bias is much smaller and the segment will last much longer
    Just on multiplexing, NPN's are more efficient for switching common cathode, and PNP's for common anodes. Here’s an example of using an PNP and NPN for a common cathode segment display;
Reply to Thread
  1. Looking for RGB LED PLCC4 (Common Cathode)
    By 2camjohn in Datasheets, Manuals or Parts
    Latest: 12th May 2006, 07:55 PM
  2. 2N7000 does this work? (in a common anode display)
    By William At MyBlueRoom in General Electronics Chat
    Latest: 24th April 2006, 07:13 PM
  3. Common Cathode 7-Segment
    By Deathshead in Electronic Projects Design/Ideas/Reviews
    Latest: 11th February 2004, 11:22 PM
