Old 7th March 2007, 11:51 AM   (permalink)
Default amp meter needed ?
does the amp meter need to be in this circuit ? for it to work? its a 12v battery charger
gigster is offline
Old 7th March 2007, 12:14 PM   (permalink)
No it doesn't, although it's a VERY good idea to include it. You should also use a special transformer designed for battery charging, these are designed to current limit - a normal transformer may well destroy itself on a flat battery. There's also no need for the capacitor in a crude battery charger!.
Nigel Goodwin is online now
Old 7th March 2007, 12:28 PM   (permalink)
so a 120v \ 12v 5amp transformer wont work? I made the charger and had a volt meter hooked up to the battery leads but when I plugged it in the diodes blew.I would buy a charger but where Im at (not in usa) they want 100+ dollars for a manual 6a charger.
Is there something I can add to protect the trans.?
gigster is offline
Old 7th March 2007, 01:02 PM   (permalink)
Add a current limiting resistor - it will need to be a high wattage one!.
Old 7th March 2007, 01:07 PM   (permalink)
hi gigster,
One of the reasons the diodes failed is because they are only rated for 1 amp.
If you have a 12Vrms 5amp transformer, you should have at least 5amp diodes, I would goto 10amp, if possible.
Connect a 5amp slow blow fuse in the output from the charger to the battery. [say, in +V lead]
The charger should also be mains powered from a fused supply, 3A fuse should be OK.
I would also ground the -V supply from the charger to the mains ground, just in case the charger transformer develops a fault.
As chargers are sometimes used outdoors, it would be advisable to use a RCCB in the mains supply line.
EricG
What type of battery are you going charge??
ericgibbs is online now
Old 7th March 2007, 02:01 PM   (permalink)
And provide adequate cooling for the 10 Amp diodes.
At 6 Amps they will dissipate around 4.2 Watts each.
Also have the series resistor on standoffs because it will get hot.
RODALCO is offline
Old 7th March 2007, 05:18 PM   (permalink)
Ok thanks! I think I got it now.And automotive batteries to be charged
gigster is offline
Old 7th March 2007, 09:11 PM   (permalink)
the current limiting resistor goes in the hot main wire? if so Im calculating with 120v and 5amps? how many ohms resistor ? 5X24=120 but its not a 24ohm res and is it the kind thats in like a ceramic rectangle?
gigster is offline
Old 7th March 2007, 11:15 PM   (permalink)
5 Amps at 120 Volts is 0.5 Amps at the primary side of the TX.
A 12 Volts lead acid (car batt) requires between 13.7 and 14.4 Volts to fully charge.
At your TX secondary you should aim for an output voltage within that range.
A good value to start with is 10hm: which will give you a 5 volt drop at the primary and about 0.5 V at the secondary.
Rating should be 2.5 Watts. Get a 7 Watt ceramic wirewound resistor or put smaller ones in parralell. 3 of 30 hm: 2 Watts each (makes 10hm: )
You can do a bit of trial and error here. Be carefull with mains wiring and put on well insulated standoffs.
A batt charger is self regulating anyway. Initial high charging current when batt is flat, voltage of batt increases, hence less charging current, till a status is reached that charger volts equals charged batt volts.
RODALCO is offline
Old 8th March 2007, 07:51 AM   (permalink)
I got some 10 amp diodes they have 4 pins I just use the + & - pins correct?
gigster is offline
Old 8th March 2007, 07:56 AM   (permalink)
I would fit a resistor in the secondary side, NOT the mains side - either in one of the leads from the transformer to the bridge, or in the positive lead to the battery.
Before I actually got round to buying a battery charger (which cost very little anyway), I used to 'throw something together' whenever I needed to charge a battery. A simple and easy current limiter is a bulb, try a headlight or foglight bulb in the positive lead and see what current you get - if the battery is dead flat the bulb will even light to tell you!. I used to use an old front foglight, which was a damaged one I saved - this always worked fine.
Old 8th March 2007, 08:01 AM   (permalink)
sounds like you got 10A bridge rectifiers. If there are 4 pins, 2 should be labelled with + and - and 2 should be labelled with ~
The ac voltage goes to the two pins labelled ~ and the two pins with + - will provide rectified DC voltage
'Intellectuals solve problems. . . Geniuses prevent them.' . . . Albert Einstein
fingaz is offline
Old 8th March 2007, 10:49 PM   (permalink)
well is this what a higher amp diode looks like?
gigster is offline
Analog Meter windozeuser General Electronics Chat 19 3rd October 2007 03:44 PM
Simple Field Strength Meter ElectroMaster Electronic Projects 8 14th June 2007 02:07 PM
Meter Data Sheets Overclocked Datasheet/Parts Requests 4 12th June 2006 11:26 PM
Help needed with LED Bar Current Meter! blue7hand Electronic Projects Design/Ideas/Reviews 6 28th February 2005 12:40 PM
Panel meter, analog VS digital Johnson777717 General Electronics Chat 7 23rd June 2004 12:33 AM
