Old 6th March 2007, 02:44 PM   (permalink)
Default Help needed on LED driver
I hv just found a LED driver from the instructables.
The components are:
R1: approximately 100k-ohm resistor
R3: current set resistor - (0.5/R=desired I)
Q1: small NPN transistor (such as: Fairchild 2N5088BU)
Q2: large N-channel FET (such as: Fairchild FQP50N06L)
LED: Luxeon
the Q2 isn't avaliable in my country
Wt other tansistors can i use?
eg. 2SX series
Can i use power mosfet instead of it?
Thx everyone~
him27hk is offline
Old 6th March 2007, 04:00 PM   (permalink)
hi him,
Ref your diagram, if my notes are correct the drawing of the MOSFET is incorrect, its showing a P channel device, is this the original drawing.
You require a 60v 50amp equivalent enhancement mode, MOSFET N channel.
The S2X series looks suitable.
Whats the specification of the LED's ?
EricG
ericgibbs is offline
Old 6th March 2007, 04:35 PM   (permalink)
Eric, I think the symbol is correct. You were probably thinking of the variant where the substrate junction is shown on the body. See
http://users.ece.gatech.edu/~mleach/.../themosfet.pdf
Ron
Roff is offline
Old 6th March 2007, 04:48 PM   (permalink)
Eric,
Here's the article in question. I found it a week or so back whilst looking for something else. Can't say that I've read it yet.
http://www.instructables.com/id/ERVL...F31U3?ALLSTEPS
Circuits for using High Power LED's
House0Fwax is offline
Old 6th March 2007, 04:51 PM   (permalink)
There is no way some LEDs in series need to be driven with a 50A Mosfet! Any N-channel power Mosfet will work or an NPN darlington power transistor will also work.
A 5W Luxeon LED has a max current of less than only 2A.
This regulated current circuit works well:
audioguru is online now
Old 6th March 2007, 05:09 PM   (permalink)
The main difference is that a MOSFET will have marginally more headroom (work with a slightly lower supply), and the bigger the MOSFET, the lower the voltage can go. Smaller MOSFETs require higher gate voltage for a given current. This would probably only be an issue if you were using just one LED. Smaller MOSFETs also have higher IR drop.
I realize that these factors are usually unimportant, but could be in some circumstances.
Ron
Roff is offline
Old 6th March 2007, 05:14 PM   (permalink)
hi RonH,
The FQP50N06 which the OP has in parts list is a MOSFET N channel, enhancement device.
According to the datasheet gate arrow' should be pointing left.
As you say possibly a variant. ???
EricG
EDIT:
arrow indicating the substrate-to-source and substrate-to-drain junction direction
Old 6th March 2007, 05:20 PM   (permalink)
Originally Posted by ericgibbs
hi RonH,
EricG
Eric, it's actually an arrow indicating the substrate-to-source and substrate-to-drain junction direction. Below is a drawing from the link I had in my previous post.
Ron
Roff is offline
Old 6th March 2007, 06:09 PM   (permalink)
hi Ron,
Perhaps my more poor wording was not technically accurate, I shouldn't be so sloppy.
Should read as per RonH'
Hi HouseOfWax.
Thanks for the link, had a look thru, can't understand the OP's difficulty in choosing an alternative.
If he can't source the original device at least he must have its datasheet.
The 2SX series has a similar spec.
Eric
Edited:
Old 6th March 2007, 06:32 PM   (permalink)
hi Ron,
Eric, I wasn't nitpicking your wording. I was pointing out that the symbol in the OP's schematic is correct. Did you look at the drawing I posted? If you have evidence that this is wrong, can you post it?
Ron
Roff is offline
Old 6th March 2007, 06:57 PM   (permalink)
hi Ron,
Relooked at your dwg, agree top right MOS shows, N channel enhancement MOSFET.
As does my 'copy/paste' from the datasheet for the FQP50N064L, which is listed in the OP's parts list.
Its just that the drawing posted by the OP, shows a 'variant' in that the arrow is in the other direction.
[or am going crazy, (answers on a postcard only, please)]
Ron, I know that you are not nit picking, I welcome our technical interactive posts, hope to have many more!.
Regards
Eric
Comparing the orginal dwg,with your diagrams, 'suggests' a P type depletion, which it cant be???
Old 6th March 2007, 07:01 PM   (permalink)
I agree with Audioguru... why a power mosfet is required? a bipolar should drive a few leds no problem....
hentai is offline
Old 6th March 2007, 07:18 PM   (permalink)
hi Ron,
Regards
Eric
One of us is going nuts. Below is a comparison of the various symbols in question. All are of N-channel MOSFETs. All are correct (AFAIK).
I can't see how you equated the OP's symbol with P type depletion.
Ron
Roff is offline
Old 6th March 2007, 10:26 PM   (permalink)
Maybe he did the same thing I did. I saw the symbol on the data sheet, noticed the arrow was different, and guessed the hand-drawn symbol was supposed to represent a P-type. Thanks for clearing this up, I think.
All those who believe in psycho kinesis, raise my hand.
AllVol is offline
Old 7th March 2007, 03:48 AM   (permalink)
@him27hk:
While members debate the proper symbol:--
Yes you can use a different N-channel power MOSFET.
Tell use more about the current/power you need and maybe give some examples of examples of what you can find easily..
regards,
Mike
mneary is offline
Request for help on an LED bar graph circuit by an electronics noob. ThrowingChicken Electronic Projects Design/Ideas/Reviews 38 14th April 2007 02:09 AM
9v + LED = time? e-amature General Electronics Chat 10 1st February 2007 10:18 PM
white led driver akshayd Electronic Projects Design/Ideas/Reviews 6 28th January 2007 02:02 PM
Motor Driver Selection YAN-1 General Electronics Chat 2 13th December 2006 09:14 PM
Does H bridge driver require back-voltage protection? fabbie General Electronics Chat 2 27th October 2004 12:43 AM
