Old 3rd March 2007, 06:10 PM   (permalink)
Default general question about a bench power supply
hello all, i have a general question about bench power supplies, there's two analog displays on the front of the power supply one is for voltage and the other one for current. The first one is the voltage supplied when you attached a load to it, what does the current display for? does it display how much current your circuit is pulling or is it how much current its supplying?
raphaelriv is offline   Reply With Quote
Old 3rd March 2007, 07:04 PM   (permalink)
Hi
usually u can set a bench supply to a desired voltage which is displayed on the voltage screen even with no load then when u connect the load the current display will show u how much current is giving to supply that voltage on that load.
hentai is offline   Reply With Quote
Old 3rd March 2007, 07:47 PM   (permalink)
You've asked the same question twice; if you connect a 12hm: resistor to a 12V battery the circuit will pull 1A battery will supply 1A.
Screen name: Aloone_Jonez
Old 3rd March 2007, 09:10 PM   (permalink)
Both, the ampmeter is actually measuring the amount of current that your load is drawing.
The load determines the amount of current drawn and the power supply will deliver it until it reaches its output limit( the power supply cant force current into the load ,beyond what the load is drawing).
Some power supplies have adjustable voltage only and the load determines the upper current limit and some have adjustable voltage and current where you can adjust the upper current limit.
sam2 is offline   Reply With Quote
Old 7th March 2007, 12:44 AM   (permalink)
Default re:
thanks all this was really helpfull
Old 7th March 2007, 03:28 PM   (permalink)
some bench supplies allow you to set the overcurrent trip level. while the power supply is in the mode to change the oc trip point, you will see that on the LEDs. In normal operation, though, it is the current being supplied.
OutToLunch is offline   Reply With Quote
Power Supply question [bridge rectifier] ArcaneDreams General Electronics Chat 26 26th December 2006 02:33 PM
Power supply: Fusing to protect circuit Johnson777717 Electronic Projects Design/Ideas/Reviews 4 10th April 2004 02:19 AM
CC/CV Power Supply royce Electronic Projects Design/Ideas/Reviews 14 12th January 2004 07:06 PM
Computer Power Supply Wattage Question bryan Electronic Projects Design/Ideas/Reviews 4 30th August 2003 08:02 AM
Power supply/ current supply design inkedallusion Electronic Projects Design/Ideas/Reviews 1 17th December 2002 01:10 AM
