+ Reply to Thread
Page 1 of 4
1 2 3 4 Last
Results 1 to 15 of 56
Thread: Need help modifying treadmill.
  1. #1
    Mipoleon Newbie
    Join Date
    Mar 2007
    Posts
    30
    Default Need help modifying treadmill.
    This is my first time trying any kind of circuitry so I am very much a novice but here is what I am trying to do. I am rewiring my treadmill into a computer keyboard so that when someone moves on the treadmill hit hits the move key on the keyboard for a video game that I play.
    Here is what I have so far.
    I have a switched that is triggered by a magnet on the conveyor part of the tread mill so that with ever rotation it triggers the switch. The switch is wired into the keyboard so that it closes the circut to the specified key sending a key pressed signal to the computer.
    Here is my problem.
    Since it sends the signal each time the magnet passes the character in the game moves ackwardly. I put a few more magnets on the conveyor part which seemed to help but if the convey stops in front of the switch the character keeps running. So what I think I need is to some how wire it so that it sends a continual signal to the computer as long as the magnetic switch is being tripped. (As long as the conveyor is moving.) And stops sending the signal when they conveyor stops.
    Any help would be greatly appreciated.
  2. #2
    Mipoleon Newbie
    Join Date
    Mar 2007
    Posts
    30
    Does any one have any kind of suggestion at all for me?
  3. #3
    mneary Excellent mneary Excellent mneary Excellent mneary Excellent mneary Excellent mneary Excellent mneary Excellent mneary Excellent mneary Excellent
    Join Date
    Feb 2007
    Location
    California USA
    Posts
    3,821
    Turn off "auto repeat" on your keyboard.
  4. #4
    Roff Excellent Roff Excellent Roff Excellent Roff Excellent Roff Excellent Roff Excellent Roff Excellent Roff Excellent Roff Excellent Roff Excellent
    Join Date
    May 2003
    Location
    Idaho, USA
    Posts
    6,721
    Quote Originally Posted by Mipoleon
    I think the solution may be simple, but your description is not clear. Have someone you know read it and see if they can point out the confusing parts (or maybe it's just me).
    Ron
  5. #5
    Mipoleon Newbie
    Join Date
    Mar 2007
    Posts
    30
    It probably is confusing but here is what I want in the end.
    I would like to wire my manual treadmill to my keyboard so that when someone walks on the treadmill it acts as if someone pressed the forward key on the keyboard.
    I have figured out how to wire it to the keyboard. But I dont know how to make it so that when someone walks on the tread mill the circuit stays closed until they stop walking. So basically I want to wire it so that as long as the treadmill is rotating the keyboard acts as if the button is being pushed and when the treadmill stops the keyboard stops pushing the button.
    I hope that is clearer.
  6. #6
    dch222 Newbie
    Join Date
    Jan 2007
    Location
    UK
    Posts
    97
    You need a monostable (eg555) between the treadmill and keyboard with a period longer than the longest time between two successive pulses from the treadmill when it is running at its slowest normal speed.
  7. #7
    Mipoleon Newbie
    Join Date
    Mar 2007
    Posts
    30
    Thanks, where do I get one of those and how do I go about installinga and configuring it?
  8. #8
    House0Fwax Newbie
    Join Date
    Nov 2006
    Location
    Hampshire U.K.
    Posts
    292
    Google '555 tutorial' and look at the 'monostable' section. It should have everything you need. If you don't understand it, come back and ask.
  9. #9
    Mipoleon Newbie
    Join Date
    Mar 2007
    Posts
    30
    Ok, from what I have read I need to build this:
    From what I gather Time = Resistor x Capacitor.
    Assuming I am correct in the above, I am not sure how to determine the voltage ect. of the keyboard in order to know what kind of resistor to get. What should I do?
  10. #10
    Join Date
    May 2003
    Location
    Idaho, USA
    Posts
    6,721
    OK, here's a schematic. It should keep the relay activated so long as the treadmill makes a complete cycle in less than 11 seconds (nominally). The actual time will be a function of component tolerances.
    You can use a 12 volt wall wart for power. A 9 volt one would probably also work.
    Ron
  11. #11
    Mipoleon Newbie
    Join Date
    Mar 2007
    Posts
    30
    Thank you very much Ron for that schematic. It would have taken me forever to figure all that out.
    I wonder if I could bother you for one more favor. I just measured the rotation on the treadmill. At the slowest speed it completes 4 rotations per second. Would you be able to tell me what the numbers on the components would have to be to keep the signal going as long as the user completes a rotation within .25 seconds?
  12. #12
    Join Date
    May 2003
    Location
    Idaho, USA
    Posts
    6,721
    Change C1 to 220nF (0.22uF).
    Ron
  13. #13
    Mipoleon Newbie
    Join Date
    Mar 2007
    Posts
    30
    Is that all?
  14. #14
    Join Date
    May 2003
    Location
    Idaho, USA
    Posts
    6,721
    Is that all?
    You could add some little jingle bells and an incense burner.
    Yep, that's all.
    Ron
  15. #15
    Mipoleon Newbie
    Join Date
    Mar 2007
    Posts
    30
    Do the down arrows represent ground or -12V?
+ Reply to Thread
Page 1 of 4
1 2 3 4 Last
  1. Need some help modifying alarm
    By corradokng in forum General Electronics Chat
    Latest: 5th January 2007, 10:16 AM
  2. Modifying a Hot Plate
    By George L. in forum Electronic Projects Design/Ideas/Reviews
    Latest: 8th August 2006, 08:04 PM
  3. Modifying a usb web cam
    By spirosd in forum General Electronics Chat
    Latest: 10th February 2006, 12:52 PM
  4. Modifying frequencies in a 555 timer
    By redtalun in forum Electronic Projects Design/Ideas/Reviews
    Latest: 15th November 2003, 12:11 AM
  5. Treadmill 16pin female connector for painted ribbon cable.
    By Manicmechnic in forum Datasheet/Parts Requests
    Latest: 15th September 2003, 04:02 AM
Tags for this Thread
