Old 1st March 2007, 09:46 PM   (permalink)
Originally Posted by Gaston
can you tanslate boddged? i haven't heard of that in the states
Yeah, BODGED means fixed, but in an unsafe way. . . basically, bodged means that wohever deals with it after gets a nasty surprise
'Intellectuals solve problems. . . Geniuses prevent them.' . . . Albert Einstein
fingaz is offline
Old 2nd March 2007, 12:42 AM   (permalink)
we call that "jerry" rigged over here. or something that would offend some people so i won't mention it here
Gaston is offline
Old 2nd March 2007, 12:59 AM   (permalink)
I'm confused now. All this talk about safe voltage. I was always taught that it was the current that killed/injured you, not the voltage?
matthewlittle2006 is offline
Old 2nd March 2007, 01:47 AM   (permalink)
Yeah, my dad used the 'N' one a lot when I was a kid... He hated that I could take a useless piece of trash, and make it work without buying parts. Never understood it.
HarveyH42 is offline
Old 2nd March 2007, 02:04 AM   (permalink)
Originally Posted by HarveyH42
Just out of curiousity, why do you want to touch it anyway?
The old printer is obselete, but the power supply could become usefull in my electronic projects.
I just wanted to know if it was safe.
Screech is offline
Old 2nd March 2007, 02:57 AM   (permalink)
Safe is a relative term... Household current is 'safe', unless you stick your fingers in the outlet, or take a bath with it. Don't be careless with electronics, there are worse things then a little shock that can happen.
Old 2nd March 2007, 03:39 AM   (permalink)
E=I*R.. so voltage determines how much current flow for a given resistance. everyones body has different resistance within certain limits so you can kind of determine a range of voltages that will produce a harmful current in the body
Gaston is offline
Old 2nd March 2007, 03:41 AM   (permalink)
It's the current that kills you, but you need enough voltage to drive the current through you. A low voltage source capable of delivering a million amps won't do anything since there is not enough voltage to drive that current past your skin resistance. Also, a high voltage, low current source like static electricity won't do much either since although it can drive the current, there's no current to drive!
dknguyen is offline
Old 2nd March 2007, 01:30 PM   (permalink)
Don't test with your finger, use a meter. Although... Even though I bought a meter that reads temperature, seldom dig out the probe to check and see if components are hot. Got a nasty burn off an LM317T...
Old 2nd March 2007, 01:39 PM   (permalink)
Always lick your finger before you touch a hot component - the sizzle warns you before you burn!
Nigel Goodwin is online now
Old 2nd March 2007, 02:24 PM   (permalink)
I think that's a derivative of the real term "jury rigged" from the days where both prosecuting and defense teams tried to skew a jury panel in each of their favor.
HiTech is offline
Old 2nd March 2007, 02:54 PM   (permalink)
I think its a term soldiers used describe bombs and traps left by the japanese in WWII...
Old 2nd March 2007, 05:05 PM   (permalink)
yes!.. I used to use that slang term.. but I've moved on.. now I use terms like:
Hacked
Hack job
Mod
Rats Nest
Spaghetti
Kludge
Optikon is offline
Old 2nd March 2007, 09:05 PM   (permalink)
In Australia, "jerry" was used in WWII as slang for German.
Hence jerry can (a can for holding petrol (gasoline in the US)) and jerry built - something badly built.
These terms are still used these days but not as frequently.
Len
ljcox is offline
Old 2nd March 2007, 10:07 PM   (permalink)
The British safety standards say the absolute maximum voltage you can allow the user to touch in dry areas is 60VDC or 25VAC.
Screen name: Aloone_Jonez
Hero999 is offline
Touch Sensitive Switch (Take 2) MonkeyMera Electronic Projects Design/Ideas/Reviews 7 2nd October 2007 11:05 PM
multiple touch switch problem sstimuluss Electronic Projects Design/Ideas/Reviews 3 15th January 2007 03:03 AM
touch switch.electronic lock RMIM Electronic Projects Design/Ideas/Reviews 16 4th September 2006 02:52 AM
about usb touch screen report ? who can help me ? kite.rui Micro Controllers 0 16th February 2004 02:54 AM
Gio Touch Lamp Replacement Circuit Help needed! sbuc General Electronics Chat 0 15th November 2003 05:41 PM
