| Hi, I'm currently building an IR-decoder (38 kHz) that retransmits the info over a RS-232 connection. This is my first project that actually uses such a large number of "pins" (40 for the PIC microcontroller plus sixteen for the max232 plus display plus the crystal, capacitors, resistors, etc.) Currently I have the thing running on a solderless breadboard and would like to transfer the whole to one of these prefabricated PCBs (the ones with the horizontal stripes - BTW, what is the correct name in English for those things?). I would like to "optimize" the layout before starting to solder (like trying new positions for components). Is there any free PCB layout program out there that can simplify my task? For this project to use a layout program is almost a case of overkill, but I'd rather start early since for my next project I will certainly need it (and why not, I'm thinking about buying one of those "budget" kit with everything you need to create your own PCBs). Some suggestions? Thanks! Regards, Gonzalo | |
| | (permalink) | |||
See more: http://en.wikipedia.org/wiki/Stripboard Quote:
One idea: http://www.mitedu.freeserve.co.uk/Prac/vero/vero.html Actual layout software, which I have never even downloaded (much less used--so YMMV): http://www.heyrick.co.uk/software/verodes/index.html This one I also have not used, but several posts online indicate that it's quite wonderful: http://web.archive.org/web/20030502...pboardMagic.zip Quote:
Hope this helps get you started! Torben Last edited by Torben; 28th February 2007 at 10:10 PM. | ||||
If you do a little searching, you will find lots of information on the subject and I would certainly not waste may money on any type of kit. | ||
You can get the free version of Eagle from http://www.cadsoft.de . You are limited to 10cm x 8cm PCB size in the free version, though. As far at the PCB kit goes, my limited experience agrees with Rolf. Skip it and save money. Google for 'diy pcb' or similar and you'll get full instructions. Torben | ||
Not exactly free, but cheap enough to make it worth buying : http://www.abacom-online.de/uk/html/lochmaster.html
__________________ ==== Shax. ==== A bus station is where a bus stops... A train station is where a train stops... On my desk I have a work station... Nuff Sed!!! | ||
| Thanks a lot for your ideas!! I will try some of these software! As for the PCB kit I was refering to, what I meant was mostly to buy the UV-lamp kit, the etching product and some kind of plastic basin for the etching process (plus some pre-sensitivized boards). Regards, Gonzalo | |
| pcb layout program? | timtalk | Electronic Projects Design/Ideas/Reviews | 15 | 4th February 2006 01:42 AM |
| FREE Simulation Program From TI. | chemelec | General Electronics Chat | 3 | 12th July 2005 09:50 PM |
| Online PCBs with parts, free PCB layout software. | Pad2Pad | Electronic Projects Design/Ideas/Reviews | 1 | 21st April 2004 08:22 PM |
| PicBasic Keypad program | Sora | Micro Controllers | 0 | 20th April 2004 08:02 PM |
| free pcb layout | jam | Robotics Chat | 7 | 14th March 2004 01:44 PM |
