| hi guys, this might be stupid but i was wandering why cant we store ac as dc in batteries..it should not necessarily be batteries but in like a capacitor bank..even if it cant be stored for a long time ,isnt there a way to store it for say a minute or two... thks | |
| It's kind of because if you input AC into a battery or capacitor or something, the second half the cycle empties out the charge that the first half of the cycle put into the storage device since it they are of opposite polarity. It's not so much storing AC or DC as storing energy. Using something like a flywheel would probably work to store AC since the spinning can be hooked up to something else to make the sinusoid waveform...or you can just store DC and use an inverter to turn it back into AC again (that's what motor drivers do and power converters). WHat are you trying to do exactly? Power an AC device from stored energy? | |
| You can store AC power, but not for very long, if you connect a parallel resonant capacitor and inductor an AC power supply then disconnect it, the AC voltage will be stored for a short time before dieing away.
| If you think about DC like water flowing in a hose, and AC like a vibration, you should begin to see the analogy - you can pump water into a water tower to store it, and later you can get a lot of the energy back by releasing it. How would you store a vibration? Something along the lines of a tuning fork would be the idea - this is the analog of a resonant inductor/capacitor circuit (AKA "tank circuit") - but this isn't really feasible to implement for effective energy storage. In the tuning fork, friction from the air and the material it's made from prevent it from storing vibrational energy for very long - it's even worse in the electrical case. Quote:
I believe I once read an article about using superconductors to make a resonant tank circuit which could store energy much more efficiently - though you had to keep it immersed in liquid nitrogen or something to make it superconducting...
__________________ EEgeek.net | ||
| It's easier to convert the AC to DC, store that and then use an inverter to create AC. Direct storage of AC is pretty useless for anything more than a few cycles.
| WHat are you trying to do exactly? Power an AC device from stored energy?[/quote] Not exactly but like the UPS converts ac into dc then store it into batteries ,i was thinking of eliminating the bulky batteries and find some way to store ac for some time(the least required to safely turn off the pc).i was thinking of converting the ac supply frequency into a very low frequency say 1 Hz then store it into resonant circuit and then reconvert it into 50Hz ac when needed. | |
| I thought PCs use supercaps on the mother board after the AC-DC converter to store DC in order to allow the processor and HD a few seconds to finish writing all data to the harddrive. Maybe this was only some computers. If you want to risk it...you can do the same thing stick a few supercaps or something in parallel with the outputs of the powersupply...but be careful...and investigate it first. Make sure votlage ratings and capacity are enough and that the powersupply can handle the initial inrush current. | |
| First off, how would converting from 50Hz to 1Hz and back be easier than converting DC to AC and back? Second, why would storing energy at 1Hz be easier than storing it at 50Hz? Third, do you think that the storage elements (tank circuit) would actually be SMALLER than batteries with comparable capacity?? Just as a quick reality check, in a resonant circuit, the energy goes back and forth between voltage on the capacitor, and current through the inductor - so at one point in the cycle, all the energy is contained in the capacitor. Go look at the energy capacity of a big capacitor, and then compare it to the capacity of a similar-sized (physically) battery. Add in the huge inductor that's going to be the other half of the resonant circuit, and the battery is going to very easily win for capacity vs. size - plus, again you have the issues of the significant losses in the resonant circuit making energy storage impractical for the periods of time you're looking for, even if you didn't care how big and expensive your storage elements were.
| i supose you could charge one battery with the positive half of the cycle and another with the negative half. then just use transistors in a push pull configuration and output a sine wave with a signal generator. and as far as computer ups's are concerned. wouldnt it be simpler to just store the 12, 5 and what is it 3.3 volts seperatly and just feed the voltage dirctly to the computer during a power outage? | |
The second part of what you said is exactly the job that a regular, cheap, commercial inverter will handle for you. Storing 12v, 5v, 3.3v, -5v, and -12v in separate batteries would also not be a great plan. It would make more sense to store a single voltage and run a DC-DC converter to power the computer from there full-time. But, all of these ideas are exactly what you can already achieve by just buying a (usually inexpensive) commercial UPS.
| i'm not saying its better, i was just talking hypotheticaly that it could be done that way. as for the ups. the only part that doesn't make sense to me is to convert from ac to dc. then from dc to ac, then fron ac to dc again. just seems like it should be from ac to dc one time | |
| what i am sugesting with the ups is. to convert it to dc one time and have the power supply able to run the computer and charge the battery or batteries at the same time basicaly in parallel with the devices in the computer. when the ac power goes off there will be power from the battery ready to go. | |
However, because they're not produced in such huge quantities as inverters and AC ATX power supplies, it's going to end up costing more than inverter+AC ATX PSU. It should be a lot more efficient though - many DC-DC converters manage efficiencies of 90% or more, whereas the efficiency of the combination of inverter+AC ATX would be much, much lower.
| I didn't know they made a 12 volt atx power supply. that would make it easy. | |
| AC to charge Nicads? wtf? | joecool85 | General Electronics Chat | 33 | 9th May 2007 07:03 AM |
| Amplifing AC Signal & Shifting DC Level | Ayne | Electronic Projects Design/Ideas/Reviews | 18 | 1st March 2007 02:19 AM |
| Ac step down | Fahime | Electronic Projects Design/Ideas/Reviews | 34 | 27th January 2007 11:25 PM |
| Ac Generator | earjun | Electronic Projects Design/Ideas/Reviews | 3 | 25th January 2007 05:16 PM |
| single phase AC motors | blazer4 | General Electronics Chat | 1 | 16th January 2007 06:13 AM |
