| I want to do a simple test, just make sure the relay can energise It is 240v ac coil so is it just a case of applying the live and neutral across the coil and it will energise or is there something else I need to add with it being mains voltage thanks | |
| If you are in the US, either live wire is 120V to neutral. To get 240V you need to use the 2 hot wires ( L1 & L2 ) like a dryer or oven.
__________________ C:\WHUT ? Beware the asterisk * | |
| If you are not in the US, and the normal supply is 220V~240VAC, then YES, you simply connect L and N to A1 and A2 respectively | |
| hi pilot, As your 'Location:' is in the UK, just use the local 240Vac mains supply. As you dont know the 'history' of the relay, use a 3A fused plug, just in case its faulty. EricG | |
| You could also connect it in series with a 100W light bulb just to be on the safe side, though I personally wouldn't bother.
| Question on running a relay | bryan1 | Electronic Projects Design/Ideas/Reviews | 9 | 21st May 2008 09:36 AM |
| Relay Question | yukanti | General Electronics Chat | 3 | 13th March 2005 09:42 AM |
| Pic to Transistor to Relay, Amperage handeling question | iso9001 | General Electronics Chat | 21 | 1st July 2004 07:14 AM |
| Simple relay question.. | Swifty | Electronic Projects Design/Ideas/Reviews | 11 | 10th February 2004 05:31 AM |
| Relay Question....... | Shocky | Electronic Projects Design/Ideas/Reviews | 8 | 23rd November 2003 09:43 PM |
