| If anyone is interested in high current(over a few amps) power supply, then I can recommend the following link. The author explains clearly why he need to use a 19V secondary transformer for a 13.8V 20A DC regulated supply. 13.8V 20A linear power supply
__________________ L.Chung | |
| Thanks, thats a good site. I like the SWR meter. sam | |
| | (permalink) | |||
| I don't completely agree with that article, I agree that people do tend to undersize things (I sometimes do on the bases that it not only saves money and I probably won't use it at full power very often) but there's over sizing things to the point where it becomes unnecessarily expensive and bulky. I would choose a 15V transformer minimum and no higher than 18V at this current. Quote:
We need to calculate the equivalent series resistance to model this correctly. Suppose the 15V 30A transformer regulation is 5%, the off load voltage will be 15.75V but if it's loaded with a resistive load that draws 30A then the voltage will drop to 15V, the equivalent series resistance will have 0.75V across it at 30A, therefore ohms says it will be 0.75/30 = 25m Accounting for the series resistance and the rectifier voltage drops, LTSpice says the ripple will be 2.2V, the peak will be 18V and the valley is just over 16.6V, if the regulator drop is really just 2V then we have 0.8V to spare. I do agree that if the mains voltage is on the low side it could still be a problem but this normally isn't the case in the UK. I don't think I've ever measured a voltage below 228V, it's normally 235V to 240V. Quote:
The only real disadvantage is they can be destroyed but high gate voltages but that's pretty easy to fix by adding a zener across the gate and source. I do agree that it's better to use negative devices, PNP bjts and especially P-channel MOSFETs are more expensive for the same rating then their N-channel/NPN counterparts. http://ludens.cl/Electron/Ps20/ps20.gif What's going on with the µA741? I would use a real op-amp like the TL081 that will give half decent transient response and would consider using a proper little regulator IC like the LM723. I have built MOSFET regulators before with dropout voltages well below 100mV. A good quality MOSFET design should give good performance at this current even with a 14V transformer and a low mains input voltage.
__________________ I also post at the following sites: http://www.stop-microsoft.org http://www.heated-debates.com Screen name: Aloone_Jonez And http://www.silicontronics.com, same screen name as here. | ||||
| Sorry for my late answer Yes, that's right, it's a shelf transformer, so I won't buy a 25.5Vrms (18V) transformer. I'm using it to power my motorcontrol for an electric car motor. It uses approximally 6-7A at 18V, which is the decired voltage for my purpose. But I can see, that a 7.5Arms transformer won't give 7.5A (my mistake), but 5.3A can be enough. Otherwise if I want more direct current I can parallel two transformers to give me 10.6A current. Now to the voltage question. The full wave bridge rectifier has a nominel dropout voltage of ~1.42, but at higher temperatures (the hign current) it can increase to the before mentioned almost 3V. But my 28Vrms transformer will give 19.8V - ~3V = 16.8Vdc when coming out of the bridge - right? That's not enough to be 18V, but the 3V are also in worst case scenario. Using two 18.000µF in parallel (so the max ripple is 2.5%) the only thing left is to regulated the power supply, but how? Using an expensive switcher? Quote:
| Another question: The datasheet for the toroidal transformar says: Pri.: 0V - JOINT - 220V-240V Black-yellow/yellow-green-brown Sec.: Blue-blue: 22V-4A Yellow-yellow: 28V-7,5A Red-red: 19V-2,6A How to wire the primary wires? | |
| Hang on just a second, there's something wrong here. I don't believe that a remote control will use this much power; are you sure you haven't mad a mistake?
| A remote control? Are you sure it's the right thread? | |
I believe I've answered your question in another thread.
| Since you're using this as a supply for a motor controller, the voltage probably doesn't have to be tightly regulated. For that matter, it also probably can tolerate a lot of ripple. Re-check the controller specs and see what the maximum and minimum input voltages really are. If it's a closed loop PWM, there might be a lot of range. | |
| Got a new EVBoard How do i supply power to it? | cubdh23 | Micro Controllers | 2 | 3rd August 2007 10:39 AM |
| 24v DC Power Supply (Help & Information Wanted Urgently) | ampthetex | Electronic Projects Design/Ideas/Reviews | 5 | 17th November 2006 01:45 PM |
| Power Supply for a project to be powered within an Auto? | hexibot43 | General Electronics Chat | 16 | 8th September 2005 03:36 PM |
| Power Supply Failure | Joel Rainville | General Electronics Chat | 8 | 24th August 2005 02:42 PM |
| Low current power supply from stored current. | McGuinn | Electronic Projects Design/Ideas/Reviews | 12 | 20th January 2004 07:15 AM |
