Old 22nd February 2007, 04:08 AM   #1
Default Single V.s dual!
Hello Everybody,
I can remember some time ago when I wanted to make a circuit while I had to link two circuit together, one was a bridged dual voltage supply amplifier and the previous circuit was a single ended circuit (Sorry I am not remember what kind of circuit). I mentioned the question here but I no one gave me a perfect and pervasive response.
As a rule of thumb, is this possible to do that without any consideration to anything? I am not able to think about the wave form of the first stage and the second stage while the base voltages are different!
My opinion is that when I want to make a similar circuit I must convert the first stage to a dual supply circuit or the second stage to a single ended circuit,
But I guess I am not true
Any idea please?
Good judgement comes from experience, experience comes from bad judgment
epilot is offline
Old 22nd February 2007, 04:55 AM   #2
It is best to have two circuits have the same power supply method if they link together. Most circuits do not need a dual supply voltage. Bridged power amps are used in cars with just a single supply voltage.
audioguru is offline
Old 22nd February 2007, 06:08 AM   #3
See this please: http://www.alldatasheet.com/view.jsp?Searchword=LM1876
This power amplifier needs more components when used as single supply.
there is not any schematic about braided single supply too.
epilot is offline
Old 22nd February 2007, 01:49 PM   #4
The LM1876 doesn't work very well as a bridged amplifier. Most bridged amplifiers have nearly 4 times as much power output when bridged because the voltage swing is doubled and the current is doubled. The LM1876 has only twice the power output when bridged but it gets 4 times as hot.
Here is a simple car amplifier IC that is bridged and has a single supply voltage. With a 14.4V supply its output power is 15W into 4 ohms at clipping:
Old 22nd February 2007, 10:00 PM   #5
the rule of thumbs, is to keep all the Grounds tied together, otherwize, the 2 circuits cannot 'communicate' together
Ibrahim Kamal
check my electronics and robotics page: http://www.ikalogic.com/
ikalogic is offline
Old 10th August 2008, 04:40 AM   #6
Hmm...but what if one circuit has a Positive Ground and the other is Negative Ground?
TRexall is offline
Old 10th August 2008, 10:48 AM   #7
Then unless you're using DC signals (in which case you need an isolation amplifier) join them with an AC coupling capacitor.
if I know the answer.
Hero999 is offline
Old 24th August 2008, 11:33 AM   #8
Originally Posted by epilot View Post
Hello Everybody,
Any idea please?
not so a single amp will have a bias on the output to make linear all you need is get rid of the DC how a cap.
neon is offline
dual, single
Dual counter bananasiong Micro Controllers 45 24th March 2007 03:49 AM
Three Phase Versus Single Phase For EV fzn10 General Electronics Chat 4 31st July 2006 09:39 AM
Getting dual supplies from single supply bmwhittle General Electronics Chat 4 25th June 2006 12:46 AM
dual voltage power suply ikalogic General Electronics Chat 19 30th January 2004 02:49 PM
Why op-amp needs a dual supply? Ravi General Electronics Chat 4 27th November 2003 11:27 AM
