| Hi, In packages with more than one op-amp, what is the best thing to do with the unused inputs, tie them together, tie them to GND or simply leave them floating thanks. | |
| I usually connect the unused op amp as a voltage follower, biasing the non-inverting input with half the supply voltage (any voltage in the common mode range is fine) with a voltage divider. | |
| Thanks guys, that helps alot. | |
| when designing pcb as small as possible, sometimes, i use 'unused' inputs to pass copper track right through them... | |
| I normally connect one input to +V and the other to -V and the output to nothing.
| Good point. Do you have any other ideas? What's the best way to bias it so an op-amp uses very little power? I suppose it depends on the type of op-amp, a rail-rail op-amp with a class A output stages is best biased either so the output is either +V or -V which is why I made such a suggestion.
__________________ I also post at the following sites: http://www.stop-microsoft.org http://www.heated-debates.com Screen name: Aloone_Jonez And http://www.silicontronics.com, same screen name as here. Last edited by Hero999; 24th February 2007 at 08:25 PM. | |
| PIC A/D Sampling multiple inputs | NJ Roadmap | Micro Controllers | 10 | 21st February 2007 02:54 AM |
| AMP kits that has a low frequency buzz/hum | mramos1 | General Electronics Chat | 13 | 17th February 2007 02:13 PM |
| Human Bistable | redart | General Electronics Chat | 26 | 19th April 2006 04:59 PM |
| No resistors on inputs? | Dan East | Micro Controllers | 3 | 19th May 2004 06:57 PM |
