I built a simple pulse generator with a 4MHz crystal and a 4060 counter, to get several output frequencies. I checked them in my scope, and I get quite good pulses, with less than 200ns rise and fall times. But there're other ways to do it, without crystals. http://www.interq.or.jp/japan/se-inoue/e_ckt13.htm or http://www.interq.or.jp/japan/se-inoue/e_ckt29.htm Do they have any advantage? Maybe you can change frequency more easily with a potenciometer, while the crystals only lets you some power of 2 divided frequencies. But the crystal is more accurate, isn't it? Thank you | |
Yes, the crystal is FAR more accurate. The best solution though is a PLL using a crystal as the reference, so you can switch frequencies easily and accurately.
The simple oscillators have a different frequency with each IC and the frequency changes when the supply voltage changes.
The links I posted, show 2 approaches with IC that do not depend on supply voltage, only R and C. Yes, PLL is good, but seem much more complex. | |
| | #5 | |
The links (performance) show a big change in frequency when the supply voltage is changed. The datasheets for the ICs show that each one is very different (threshold voltage) which affects the frequency.
| | #6 | |
| generator, pulse |
| Problem measuring pulse width - 12F683 TMR1, 8MHz | jess | Micro Controllers | 18 | 5th February 2007 11:00 AM |
| comparator as a pulse generator | xmat | Electronic Projects Design/Ideas/Reviews | 6 | 1st February 2005 08:02 PM |
| Tweaking a ramp pulse generator! Ahh! | winners | Electronic Projects Design/Ideas/Reviews | 7 | 15th May 2004 04:30 PM |
| Digital Pulse Generator and PIC | Barry | Micro Controllers | 7 | 11th March 2004 07:58 PM |
| 5V Pulse Generator | Brocktune | General Electronics Chat | 3 | 4th November 2003 09:11 PM |
