Old 17th February 2007, 12:20 PM   (permalink)
Default Antenna Question
Hello:
I am hoping you guys may be able to help me. I am creating a ultra small short range tx/rx. And although, I am moderatly comfortable, with electronics, I am a novice when it comes to antennas. For the reciever I am using digikey part #LTC5505-1ES5#TRMPBFCT-ND with this antenna (digikey part #ANT-315-HETH-ND). My question is this... the antenna is created so that both "ends" are connected to the circuit, but my output IC only has one output antenna connection, so how do I connect these together? The transmitter is tuned to transmit on the 315 mhz band, the recieving antenna is tuned to the same frequency. and it only needs to work for 20-30 feet. Even better would be if someone could point me to a website that would allow me to create a PCB antenna for this circuit.
Thanks in advance
meriad is offline   Reply With Quote
Old 19th February 2007, 11:32 AM   (permalink)
I dont know if this will help as my understanding of RF is limited to the 11meter band, but here goes... the broadcast antenna needs a driven element (likely the output lead from your IC) and a ground to reflect from.
the signal travel on a 1/4 wave antenna travels to the antenna tip along the Outside of the antenna then reflects off of its ground base ( Ie what it's mounted to) into the aptmosphere. This can be very directional as the RF signal "pulls or reflects if you will " toward the greatest amount of reflector.
hopes this helps in some way...
aircond_gypsy_63 is offline   Reply With Quote
Old 19th February 2007, 03:22 PM   (permalink)
Regarding the antenna, after looking at the datasheets in digikey, I think it is supposed to be a "normal mode helix".
To use this antenna, one end is connected to the antenna pin of your Tx or Rx module, and the other end is just soldered to a small pad on the circuit board, (for mechanical support, not connected electrically to anything).
I must question your use of the LTC5505 as a receiver.
This chip is intended to be used as an RF power monitor for a transmitter, it has very poor sensitivity for use as a reciever.
Your "short range" may be quite a bit shorter than you expect.
JimB is offline   Reply With Quote
Old 19th February 2007, 03:30 PM   (permalink)
Thanks for your replies, The range only has to be under 50 ft, so I'm hoping it will work, I just wasn't sure wether to connect the other end to the ground or not
FM transmitter antenna juan123 Electronic Projects Design/Ideas/Reviews 10 11th August 2006 08:58 PM
RF 433 or 315Mhz module antenna problem nikhil arora Electronic Projects Design/Ideas/Reviews 11 18th March 2006 09:43 AM
Antenna question zachtheterrible Electronic Projects Design/Ideas/Reviews 8 19th December 2005 05:18 AM
antenna design sukanya Electronic Projects Design/Ideas/Reviews 2 23rd March 2004 03:40 AM
Antenna application theory DirtyLude General Electronics Chat 5 25th February 2004 01:56 AM
