| Alright I'm trying to build the AaronCake Chaser LED circuit http://www.aaroncake.net/circuits/chaser.htm Now I'm having a few difficulties (i just put it together for the most part tonight, haven't soldered the LED's yet and am trying to figure out which connections I need to solder to on my potentiometer). So I'm looking at the circuit, there's no -9v. The negative poles on the LEDs drive straight into the ground, and the ground is 0v. Now I am pretty bad at electronic circuitry, so I may be missing something, but something just does not seem right about this. Also for the ground, how do you "make" a ground? I have all my grounds going into the long strip on my Radioshack IC board. So to sum it up *Where's the -9v? *How do I go about creating a ground? (I read this http://en.wikipedia.org/wiki/Virtual_ground but dear god it was over my head). *Well I guess that's it, look at how big of a windbag I am, all that typing for those two simple questions. | |
The "ground" connection is the 0V line in this application....
__________________ ==== Shax. ==== A bus station is where a bus stops... A train station is where a train stops... On my desk I have a work station... Nuff Sed!!! | ||
| That little "screw" shaped symbol on pin seven of the 4011 and near the resistor R3 on the 4017 is the ground symbol... it simply means a common attachment. It is the return for the negative side of your battery. All pins adjoining that symbol are connected together. Make sure the short legs of your LEDs are connected there, too.
__________________ All those who believe in psycho kinesis, raise my hand. Last edited by AllVol; 16th February 2007 at 10:50 AM. | |
| What do you mean "return"? Is my -9v hooked up to that? Without the -9v won't there be no flow in the circuit? Say I have a metal altoids bin as a case, would that suffice as a ground (would I still have to make a virtual ground?) | |
| You have a misconception about -9v. Now, the battery companies spread this mistake: -9v is suppled from this battery. No. The postive terminal is +9v, the - terminal is actually 0v, NOT -9v. Now, in most cases (exceptions are those high voltages and bipolar power, but forget those) the ground is just the negative terminal of the battery. Got it? | |
In that case, think of the altoids tin as the chassis. If a wire from the negative (-) post of your battery were soldered to the tin, and a wire run from the connection point on your perf board also soldered to the tin, then yes, you would have ground and return. But it is simplier to just wire direct from the negative battery to the circuit board. Does this answer the question?
__________________ All those who believe in psycho kinesis, raise my hand. Last edited by AllVol; 16th February 2007 at 02:12 PM. | ||
| Okay, so i made it and it doesn't work. Now I'm screwed. I don't have even the slightest clue as to what it could be. I soldered all the joints (I think correctly, I'm sure many will think otherwise), and when I test it with my 9v battery I get readings of 9.02V on the right pins (and also on the negative input). So I don't know where I should begin troubleshooting. Also it was made evident to me that I have no idea how a ground should work. So if I wire my negative post to the circuit board, do I still need to ground it to the tin? Is there any common mistakes I can look for? Anybody ever make this and have it not work, only to realize there mistake and then tell me about it? Thanks in advance. I just wish I was good at this stuff, it's so frustrating looking forward to making it and hoping it will work (whenever I make stuff now I tell myself it won't work just so I won't be disappointed). Oh yeah another thing, I don't know how fast this thing should rotate through the LED's, but I set the +/- up on the positive and negative ends of a lead and never got anything (should I have?) Last edited by GermanMafia; 17th February 2007 at 04:49 PM. | |
To start with, take the 4017 out of the circuit by either removing it from it's socket (if it is in one) or by removing the link to pin 14. Connect the black lead from a meter ( set to DC volts ) to 0v (ground) and the red lead to pin 4 of the 4011 to check that you are getting pulses. If not, the fault is with the 4011 part of the circuit. Check and check again all connections and polarities. Post pictures if you can. | ||
| Is the 4011 IC backwards? Is the 4017 IC backwards? Are the LEDs backwards? Two connections on the schematic must connect to the + of the 9V battery. Two connections on the schematic must connect to the - of the 9V battery.
| 2 connections eh? Hmm maybe a picture will do this more justice, but what about if i were to connect all the grounds to one pad (it's a long one) and then I connected the - to that pad, that would do the same thing correct? LED's should be long leg (+) to the outputs correct? http://en.wikipedia.org/wiki/4000_series Maybe what's throwing me off (although I think I got it right) is the different numbers, 1-7 pinouts are connected to the LED's, and 9-11 are as well. What's up with the different "output" numbers on the diagram (and probably the schematic)? So I bought the chips from Electronic Goldmine, they seem to be pretty old, what are the chances they are dead (there's a current going through them fine). Also one other thing, how vital is it that the capacitor is 16v? I bought the caps from radio shack and they're rated at 50WVDC, but they're 0.1 uF Ceramic Disc Capacitors. ACk this this is so frustrating. BTW Thanks for the help so far guys, I have to say this is one of the most embracing first threads I've ever been a part of. | |
| Whoops didn't see HouseofWaxes' post. Hmm there's no pulses coming, it's just staying solid at 8.7 volts. When I said "right" i meant the correct ones (the 9v input pins). Since it seems as though my 4011 is bad, a 555 could be replaced correct? Is there any 555 and 4017 circuits that would drive 10 LEDs (I've only been able to find ones that drive 2). Thanks in advance. It seems like every other one of my posts gets lost somehow. My IC's aren't backwards, and the LEDs should be hooked up with + (long) leg to output correct? So for the ground, it's still a little hazy to me. If it's connected to the - pole it does not need to be connected to anything correct? And just to make sure, although this is a stupid question, if I were to throw all my grounds onto a single pad and connect the - pole up to that pad that would be fine correct? Thanks a lot for the help so far guys, this stuff is confusing and I was (and still am) treading water, it's nice to know I now have some helpful and knowledgable people to go to. Last edited by GermanMafia; 17th February 2007 at 07:04 PM. | |
LED sequencer The 10 LEDs are controlled by the 4017. The 555 (or in your case the 4011) only supplies the clock pulse. Though, since you have made this design, it's best to try and get it working. + side of battery goes to 4011 pin 14 and 4017 pin 16 - side of battery goes to 4011 pin 7 and pins 8,13 & 15 of the 4017 Are you sure everything is connected up correctly ? ICs the right way round ? LEDs ? The resistors and the capacitor ? Last edited by House0Fwax; 17th February 2007 at 07:43 PM. | ||
| I'm not really sure of anything anymore, but I'm pretty sure that everything is hooked up correctly. What are the reasons why the 4011 wouldn't be pulsing? http://img252.imageshack.us/img252/2...lderingtn1.jpg Note my inability to solder well (I don't think I crossed any connections I shouldn't have though). It sized it down a lot, if you'd prefer a higher res one just hit me up. Also if you'd like an undoctored one tell me EDIT: better image http://img407.imageshack.us/img407/4...lderingru0.jpg Last edited by GermanMafia; 17th February 2007 at 08:43 PM. | |
| Hi, Germanmafia, First, where is the capacitor for your 4011? I can't see it. EDIT: On second look, I see a cap, but the one I am referring to should be C1, coming from pin 4 of the 4011 to one end of your variable resistor. Without this capacitor, the 4011 will not "pulse".
__________________ All those who believe in psycho kinesis, raise my hand. Last edited by AllVol; 17th February 2007 at 09:21 PM. | |
| In the first picture it's at the far left, right below the - (black) wire. in the one with all the colors it's the blue line on the lower half right side. It's a light orange color. Do potentiometers need to be grounded? I have one that has 6 pins on it (It's a 100K pot). So for a moment (it was like a minute) the thing may have been pulsing. I had one lead from the multimeter on pin 7 of the 4011, and the other on pin 14 on the 4017. The voltages were all over the map, from 8.3 -> 0 and everywhere in between. I wasn't moving at all so I don't think it was the multimeter reading a different pin or anything, but for the life of me I can't reenact that (Also, the LEDs DID not blink during this), but it must have been a fluke. Any reasons why my 4011 doesn't feel like doing anything? Last edited by GermanMafia; 17th February 2007 at 09:25 PM. | |
| Sonic Mole Chaser | seraj | Electronic Projects Design/Ideas/Reviews | 14 | 27th January 2007 08:19 PM |
| mystery chaser | musthave | Electronic Projects Design/Ideas/Reviews | 0 | 24th September 2006 11:36 PM |
| LED chaser with 555 timer | KChampion | Robotics Chat | 4 | 5th April 2005 02:12 AM |
| Chaser LED IC Help | fiveten | Electronic Projects Design/Ideas/Reviews | 1 | 22nd February 2005 02:17 AM |
| chaser lights for theater marquee | thepelz | Electronic Projects Design/Ideas/Reviews | 0 | 31st July 2003 05:07 PM |
