| I thought I might be able to simulate this circuit to teach myself how to amplify voltage, but I can't seem to get it to work correctly. RL1 is a 12v Relay for those attempting to assist me. I found that even with the 'darlington pair' the voltage is still not enough to activate the relay. Why is it the more transistors that I place in the array the less the voltage? How could I get this circuit to work? | |
| The relay is in the wrong place. It must be connected between 12 V and the collector of the transistor (you need just one). The cathode of the battery and the emitter must be tied to ground (insert a GND symbol). The resistance depends on the collector current, you probably need some kohms. | |
| I understand what you're trying to do, but even when I do those things I still can't get the relay to switch. I can however get it to switch using 3 transistors, like an extended darlington pair. Last edited by ScuzZ; 13th February 2007 at 10:53 AM. | |
| That's because 10M is too high a value, adding a further transistor works because you've then got so much more gain. | |
| The 10M resistor is to simulate water. | |
| That's what I measured the resistance at. | |
| And I bet you used a digital meter to do so!. | |
| Well I done a fair bit of googling first, but couldn't find anything. So yeah, poured a glass of water and put the probes of my digital multimeter in. What's wrong with that? | |
| why don't you try fixing your circuit arrangement (moving the relay), changing the 10M resistor to a much lower value, and then using that to get an actual idea of how the circuit is supposed to work, and then put something together and just trying it out? Your measurement of 10M ohms seems high, unless you are using distilled/deionized water, and/or a terrible electrode setup, in which case your simple transistor setup is probably not going to cut it anyway... A pair of electrodes very close together (or better, overlapped finger pairs on a PCB) would probably be much better.
__________________ EEgeek.net | |
Get the two probes from your darlington, and place them in the water, ensure the relay is in the collector of the transistors, and not the emitter - see if it works then. | ||
__________________ I also post at the following sites: http://www.stop-microsoft.org http://www.heated-debates.com Screen name: Aloone_Jonez And http://www.silicontronics.com, same screen name as here. | ||
| My Fluke digital meter measures resistance perfectly. Its max is 40M and on its lowest range it can automatically subtract the 0.4 ohms of its leads. My tap water measures 225 ohms. Acid rain might measure higher. Distilled water is nearly an insulator.
| | (permalink) | ||
| hi, Using a DVM, measured tap water as 13K to 15K for 1cm probed separation, insertion depth about 1cm. Measured filtered water [ Brita ] about 1K lower ??? EricG | |
| Good Electronic Supply's Sites, Everyone Come On In! :P | Electric Rain | General Electronics Chat | 44 | 28th August 2007 12:06 AM |
| MOSFET transistor switch/latch/power circuit | discostews | Electronic Projects Design/Ideas/Reviews | 2 | 22nd February 2006 05:30 PM |
| I need help switch mode power circuit | darkstorm | General Electronics Chat | 1 | 1st March 2005 08:28 AM |
| 0-10A and 0-30V Linear Power Supply Circuit | Candy Yiu | Electronic Projects Design/Ideas/Reviews | 9 | 2nd July 2004 01:56 AM |
| Circuit auto OFF feature after no events design | Uman | Electronic Projects Design/Ideas/Reviews | 2 | 3rd May 2004 06:34 AM |
