I have an STK500 that came with several sets of 2 connector jumper wires to connect standard header pins for various functions together. I'm trying to find a Digi-key part number for similar wires that are between 6-8 inchs long but only for one pin female on both sides. What are these style of connectors called? (No [WORD CENSORED] jokes please) Another thing I'm possibly looking for is connecting flat conductor ribbon cables to a breadboard. Anyone help me out? There are so many pages in the connectors section of the Digikey catalog I'm not even sure where to start.
I usually use the "AMP C-GRID" type connectors. There's also another type that I can't quite remember at the moment. The crimp tool is $50 (and is pretty useful), but just soldering wires to the crimp ends works too. When I run out of the little plastic holders, I tend to just use heatshrink tubing around the crimp contact. | |
Searching Digi-key for c-grid and the best I could come up with was 4 contact receptacles. I think you may have misinterpreted what I'm asking for? Just about anyone that's every opened a PC is familiar with the wires that attach things like the PC speaker and front panel LED's. They're usually 2 or 4 wide connectors, though I've seen some USB headers that had multiple single pin connectors because the header format for extra USB connectors isn't always the same. It's those one connector bits that I'm looking for. Receptacles with solder ends or pre built assemblies with both ends receptacles 6-10 inches long for connect two seperate square .1 spaced header pins together. Can you provide a part number for exactly what you're refering too in case I'm just getting bad hits searching Digi-key's site?
| http://rocky.digikey.com/scripts/Pro...3&M=50-57-9002 The catalog page is probably the most useful thing: http://dkc3.digikey.com/PDF/T071/0145.pdf | |
Have you tried the Futurlec website? http://www.futurlec.com/ConnHead.shtml Plento of connectory bits there!!
__________________ ==== Shax. ==== A bus station is where a bus stops... A train station is where a train stops... On my desk I have a work station... Nuff Sed!!! | |
| | #6 |
Looks like just the plain raw c-grid crimp pins are what I need. I think I may know someone that has a crimping tool for them as well, though I can solder them if need be. I was kind of hopeing for a housings for 1 wire connectors as well but the more I think about it it's probably just easier to use a piece of heat shrink tubeing like hjames suggested. They're marginally more expensive than the ones on the futurelec page but there are things Digikey carries that I need and I'm not gonna split it into two orders for the sake of a few pins. I'll have to browse the catalog a little more and see if I can find a generic equivilant.
| | #7 |
I went through this back in December with the AVR Dragon. Doesn't come with any jumpers or cables, and this was my very first programmer. I got luck and found some header socket in a housing with wires, just had to slip the pins out. Put heat shrink on them, but they are a tight fit when close together on the headers. Been using the ZIF socket, and haven't changed anything, but will need to do better soon. There was a thailand site that sells the cables, but couldn't get it to take my order. http://www.ere.co.th/ link doesn't seem to be working... | |
| | #8 |
I'm not sure, but is this something like what you're looking for? http://www.jameco.com/webapp/wcs/sto...oductId=126342 Well, maybe not, I just saw you were looking for female ends. For that I use Molex SL type. The holders come in many varieties, no singles though. Smallest is 2 pin. Last edited by RDL2004; 12th February 2007 at 08:42 PM. | |
| | #9 |
the housings are pretty cheap where-ever your look, but the crimp pins, holy cow are they expensive! futurlec is by far the least expensive retail source. the pins also pretty cheap on ebay the tool doesn't have to be the "Molex" tool, anything that crimps 0.100" pin headers will work - I use a Paladin CrimpAll frame with a multipurpose die set in it. Before I bought the tool, I used needle nose pliers, that worked too but what a pain.
__________________ If you don't have a planet, what good are gold bars? want to contact me directly? gmail gordonthree check out my project website: http://projects.dimension-x.net Favorite numbers: 09 F9 11 02 9D 74 E3 5B D8 41 56 C5 63 56 88 C0 | |
| | #10 |
Whoops, I guess they are Molex connectors. The other one that I get them confused with is the AMP "AMPMODU" ones. The retaining prongs are in different places which makes the housings and crimps completely incompatible between the two manufacturers. Talk about PITA.
| | #11 | |
in the search box, enter SIP-30 These are snap-apart female sockets. Solder one to each end of your wire and cover with heat-shrink. I have done the same with single header pins to make breadboard jumpers. Hope this is what you are looking for. Regards,
__________________ Creationists have a world of evidence | ||
| | #12 |
I ran across some that appear to be what you are looking for. Says they work with any header posts. http://www.basicx.com/Products/Jumpers/jumper.htm | |
| | #13 | |
Edit: It's a good thing no one responded to this post, because the female plugs described above from All Electronics would not work. I ordered some out for another purpose, and realize they will not accept the normal male header pin. correction made for the archives.
__________________ Creationists have a world of evidence Last edited by AllVol; 3rd March 2007 at 01:46 PM. | ||
| | #14 | |
http://dkc3.digikey.com/PDF/T071/P0061.pdf Umm....Chinese finger traps? seriously though...those are used on logic analyzers to the microclips for SMT chips. D. | ||
| | #15 |
I just notice the [word censored] Nigel's allowed to look up the IP of a user and tell people what country they live in ,and you can't say |_esb|an in a post without it censoring it. There's a whole lot of high end moral management going on here! <Rollseyes>
| header, jumper, pin, wires |
| Major Help Needed Please: Peltier and 2 channel fan controller needed :S | MR Spade | General Electronics Chat | 16 | 23rd November 2007 04:10 PM |
| PIC USART: Help Please | mortuzahasan | Micro Controllers | 2 | 11th February 2007 07:28 PM |
| Newcomers, please read! (PIC regarded) Upd. 0xD | Jay.slovak | Micro Controllers | 0 | 17th April 2005 02:05 PM |
| Question about AC currents and Live and neutral wires. | avinsinanan | General Electronics Chat | 8 | 2nd March 2004 08:58 AM |
| soldering jumper wires (ie. 2 protoboard holes together) | daviddoria | General Electronics Chat | 2 | 19th January 2003 04:16 AM |
