Old 12th February 2007, 01:14 AM   (permalink)
Default blown lamps
In my house I installed lamp fittings 240V, hallogen.
I replaced several bulbs last two months. Is there any problem with new fittings or house wiring to cause bolwn bulbs. I am fed up replacing bulbs.
Any idea. many thanks.
One of my mate also complainig that some bulbs are blowing his house too. He had his TV and some electrical applience got repaired due to powersupply fault. But this is completely two different areas.
Can House electrical wiring system cause this. Or the way of connection.
Thank you
mpj111 is offline
Old 12th February 2007, 02:33 AM   (permalink)
Have you checked the voltage to see if it is higher then 240v?
What type of halogen bulbs are you refering to? Are they the tube style that clip into a holder? Are they subjected to any vibration?
Make sure that the bulbs connection is good and tight so that there is no arcing.
Andy1845c is offline
Old 12th February 2007, 02:46 AM   (permalink)
Make sure you do not touch the bulbs when you install them. The natural oils from your skin can cause the glass to crack when the bulb is hot.
As for just a filament failure, the most likely suspect is loose sockets, then over voltage and then a defective batch of bulbs.
kchriste is offline
Old 12th February 2007, 04:51 AM   (permalink)
Thank you
As earlier mate said the lousie junction can cause an arc. It will reduce the life time of the bulbs or burning the bulbs. also a higher voltage can effect the bulbs to burn. Some cheapy halogens much sensitive for voltages & burning quickly.
If a bulb burned it will not much effect to the other home appliances as you said like TV’s radio’s. I think there is a voltage exceeding than the normal value in your area. Call your authority & check the voltages in your area first. If there is a voltage problem useless trying for even branded bulbs.
Gayan
My Website
http://gsmicro.blogspot.com/
Gayan Soyza is offline
Old 12th February 2007, 01:24 PM   (permalink)
As mentioned by others, check incoming voltage and general condition. Also check to be sure the fixture isn't overheating. Mfr's instructions will likely describe conditions that have to be met. As an example - some light fixtures are vented which allows heat to escape - if vents are plugged the fixture gets hotter (and so does the lamp) than intended - this will shorten life.
stevez
stevez is offline
Old 12th February 2007, 03:08 PM   (permalink)
Are you dimming the halogen lamps? If you are, that could be your problem. Halogen lamps are not designed to be dimmed, and actually need to be run at full output in order for the internal chemistry to work correctly, and thus enhance the filament life. And if you are switching on the lamps on while dimmed, you are actually accelerating the problem!!!
Our house mains supply is 230v, and doesn't vary by more than a volt or two in either direction.
I suspect 99% of the UK is also fairly constant with the supply voltage.
Shax.
A bus station is where a bus stops...
A train station is where a train stops...
On my desk I have a work station...
Nuff Sed!!!
Shax is offline
Old 12th February 2007, 04:46 PM   (permalink)
Yes, the mains is usually excellent in the UK - however the poster is from New Zealand, which I would expect to be pretty decent as well?.
Nigel Goodwin is online now
Old 12th February 2007, 06:33 PM   (permalink)
It's supposed to be within 220V to 250V, it was 238V the last time I measured.
Screen name: Aloone_Jonez
Hero999 is offline
Old 12th February 2007, 06:43 PM   (permalink)
Default Mains voltage
The mains voltage (230 Volts) in New Zealand is well regulated too, and may fluctuate only a couple of volts either way.
In winter when load controls are applied (Hotwater) perhaps for a short period the voltage may be up or down 5 or 6 volts at the time to give the tapchanger in the substations to catch up.
As already said by our other members,these lamps fail because of
High voltage
Heat trapped in fitting (insulation batts put over fittings)
Fingermarks on bulb
Vibration
Arcing contacts (especially in cheap fittings)
Lower voltage, (10 to 20% under), if lower the filament doesn't dissipate as much heat and the heat stess isn't as bad. Similar like the old valve tubes.
Nigel, how did you work out he is from NZ ? The fields are not filled in, or did you see his email address.
RODALCO is offline
Old 12th February 2007, 07:57 PM   (permalink)
Come to think of it those halogen lamps are crap, they're always burning out and they tend to take the circuit breakers with them.
Hero999 is offline
Old 12th February 2007, 09:51 PM   (permalink)
Thanks for all of you. I am getting 237V.
The hallogen bulbs I have mentioned is not a long ( with two side contacts) one. This is similar to MR16(12V type). It had good vent as well.
The other one I mentioned is not the hallagon , it is ordinary bulbs using as down light installed in ceiling. It can be a vent problam in this case because it installed to down stair. I belive there are no much room between ceiling and upstair floor to give proper vent. What could be the reason to distroy other electrical applience ( TV power supply fault and hair drier etc)
got 237 V when measures. But have no idea about power surge around the area.
I have heared about "Power line harmonic". what is that.
mpj111 is offline
Old 13th February 2007, 09:37 AM   (permalink)
Reverse IP lookup from his IP address.
Old 14th February 2007, 04:57 AM   (permalink)
Is the IP address of all users here available to all other users? If not that's blatantly invasive of Nigel, regardless of his standing in the forums even if he own's them outright. Rude doesn't even begin to cover what I'd call it.
straight answer, har har."
Sceadwian is offline
Old 14th February 2007, 09:26 AM   (permalink)
But not as rude as not entering your location! (perhaps you might take note Sceadwian!!!) - many questions are directly related to location, including this one!.
As such I mentioned his country, to avoid the usual long pointless thread where everyone just makes guesses!.
Old 14th February 2007, 06:48 PM   (permalink)
Default 237 Volts
mpj111
Your 237 Volts is normal voltage for NZ.
Generally the mains voltages vary between 233 and 238 Volts.
Check the actual voltage rating of the lamp.
Some may be rated 230-240 Volts, which should be ok.
It's better to get 240-250 Volts lamps which will last longer.
it's probably a bad batch of cheap chinese made lamps.
Personally i don't like recessed can light anyway because of previously mentioned problems.
RODALCO is offline
Van Lamps watzmann General Electronics Chat 6 1st February 2006 07:58 AM
Halagon lamps. mahinda jayasinghe General Electronics Chat 7 6th November 2004 10:19 AM
Flickering mini lamps rstuhl Electronic Projects Design/Ideas/Reviews 4 28th October 2004 07:36 PM
Ultrabright White LED and BLUE lamps for sale $0.80 each ledtronics General Electronics Chat 0 3rd April 2003 07:44 AM
i need an advice on lamps for high speed switching _4nickando Electronic Projects Design/Ideas/Reviews 1 12th December 2002 04:50 PM
