Old 11th February 2007, 07:16 PM   (permalink)
Default resistive circuit
hi people ...
In the attached circuit, if we want to find Ix,we cannot say (V1-50)/0 because this yields infinity,and we know that V1 mainly = 50V, so this expression becomes (50-50)/0, namely 0/0, which is an undeterminate quantity, so how can such a current be evaluated ...?
afesheir is offline
Old 11th February 2007, 09:42 PM   (permalink)
Here's how I solved it: Convert the current source and the 75 ohm resistor to the Thevenin equivalent. Write the two loop current equations. You have two equations and two unknowns. You don't even have to use determinants!
Ron
Roff is online now
Old 11th February 2007, 10:09 PM   (permalink)
Originally Posted by afesheir
hi people ...
The thevenin equivalent that Ron refers to is that you can take any part out of the circuit and look at back into the resulting terminals.
Calculate the voltage you see at the terminals. This voltage becomes the thevenin or open circuit voltage.
Open current sources and short voltage sources and calculate the thevenin reistance.
The equivalent circuit then is an ideal voltage source equal to the thevenin voltage with the thevenin resistance in series.
If you then put your load back in you will know what voltage and current it will run at having simplified whatever mess of impedances and sources are in the circuit to a single source and impedance.
D.
cadstarsucks is offline
Old 14th February 2007, 04:03 PM   (permalink)
Default thanks
thanks everybody for your solution, but it's well known that all methods of solution should imply the same results, however, if we say that Ix = (V1-50)/0 where V1 = 50 volts, this becomes 0/0 ...??????????!!!!!!!!!!!
afesheir is offline
Old 14th February 2007, 04:22 PM   (permalink)
"all method of solution should imply the same results.." yes, that's true.
0/0 is not a method of solution (indeterminate is not a solution)
You asked how and the answer was given. So what's the problem?
Optikon is offline
Old 14th February 2007, 04:33 PM   (permalink)
Both ends of your "zero ohm resistor" are the same node!
Ron
Roff is online now
I need help in designing a circuit chefach Electronic Projects Design/Ideas/Reviews 13 27th September 2007 11:14 AM
power electronics circuit analysis ptewright Electronic Projects Design/Ideas/Reviews 2 25th November 2006 08:16 AM
Circuit auto OFF feature after no events design Uman Electronic Projects Design/Ideas/Reviews 2 3rd May 2004 05:34 AM
HELP! a digital signal to close a circuit fireismyflag Electronic Projects Design/Ideas/Reviews 2 22nd March 2004 10:45 PM
Circuit functioning very strange. Why? Cyclone Electronic Projects Design/Ideas/Reviews 12 4th November 2003 12:30 AM
