Hi all.
I'm thinking of using NaOH as a developer for my presensitized PCBs. The PCBs are coated with type FR-4 positive resist. (Don't know what FR-4 means) What I've got is pure crystallized NaOH, but to which ratio do I dissolve it to? From the wholesales website (ELFA), the developer they sell (Expensive!) is said to contain NaOH, but doesn't mention if it contains anything else. Their water to developer ratio is 20g to 2ltr water. That's 1:100 grams NaOH to mil-liters water. Any suggestions, or experience with NaOH? What would be a good water temperature? And the water to developer ratio? I think I've seen acetone being mentioned as a developer too. Has anyone done this? I've also read about people putting all sorts of fancy chemicals into the developer, are they really necessary and what do they do? Sorry for always posting such long-winded questions |
NaOH, otherwise known as Sodium Hydroxide or Caustic Soda. I'd start with a small amount in water and see what happens. Add more crystals to water if it needs to be stronger. I don't think it takes much - the crytsalized packets of naoh that I use as developer are pretty small compared to the liter of water I put them into.
The manuf. states the water temperature should be room temp, so what, 20-22C? When you're experimenting, remember to add crystals to water, not water to crystals.
If you don't have a planet, what good are gold bars? want to contact me directly? gmail gordonthree check out my project website: http://projects.dimension-x.net Favorite numbers: 09 F9 11 02 9D 74 E3 5B D8 41 56 C5 63 56 88 C0 |
The reason being caustic soda reacts with water creating heat. One of the guys that works at the metal finishing shop I do routinly added causitc soda to a cleaning bath while it was cold, till one day he wasn't paying attention and did it while the tank was still hot. The extra heat generated was enough to cause the entire 100 gallon tank to start boiling.
could, mum, but I be a cat, and no cat anywhere ever gave anyone a straight answer, har har." |
I'm thinking of doing this:
Do you reckon the ratio's ok? |
having a weak solution will work, the developing time will just be lengthened. Having too strong a solution however will strip all the resist, not just the exposed parts. so start with 5 or 10 grams and put in your pcb. agitate it continuously (I use a foam paint brush). If you don't see anything in 2-3 min, add another 5g of crystals. When my developer is "fresh", it starts working the instant I drop in the pcb ... it looks like the resist starts "smoking" in the water.
I used a NaOH bath, and it worked beautifully.
I mixed 5 grams NaOH crystals in 1/2 liter water. It dipped the PCB into the solution, and it started smoking immediately. I panicked I could see the schematics now, where there before was non (My PCBs have no visible/transparent resist). I went ahead with the etching, and after a looooong time, the copper started to fade. Overall I'm very pleased with the results. The image I've attached is a test-strip i did (30mm x 100mm), with varying UV exposure times (1 min. intervalls). Maybe I should post my UV-box experiment, now that I know it works so well... |
Wops, forgot the images....
skann2.jpg This is after I cleaned it up with acetone... skann0001.jpg ...And after the drilling. I think i used a 0.8mm drill bit. Need to get a smaller one I think... BTW, the UV-exposure unit uses LEDs, and not fluorescent tubes... |
| Need Low Volume Water Pump | Noggin | General Electronics Chat | 27 | 26th June 2007 04:32 AM |
| submerging a pressure sensor under water? | AndyWatson | Electronic Projects Design/Ideas/Reviews | 14 | 26th October 2006 09:37 AM |
| measuring the resistance of water | kleen | Electronic Projects Design/Ideas/Reviews | 20 | 6th August 2004 03:50 PM |
