| I read an artical on line that described plating PCB's using tinning crystals. The artical said it was a simple procedure that worked very well. The only thing it did not mention was where to get them, or a brand name. Does anyone know about this? thanks sam Last edited by sam2; 6th February 2007 at 12:42 AM. | |
| allelectronics.com I think has it. Seach the web for tinnit (or go to allelectronics.com and search there). It is a powder (for shelf life). The $10 pack will do a pint, you drop the board in and 5 minutes it is tinned. It is more of a chemical process. EDIT: http://www.allelectronics.com/cgi-bi...IN_PLATE_.html | |
| Thanks mramos1. I also fond this there http://www.alliedelec.com/Search/Pro...C6738077F4E17F Sam | |
| I used the liquid type in the past and it lasted for some time (a long time just took longer to tin). But the power should last longer as it is a powder. Also, you can do as little as you want and put it in a bottle and use it over and over. I have only used the liquid, but the powder does seem to sound better. I have not tried it. Maybe someone else has some input. | |
| I thought use solder to do tinning?
__________________ Superman returns.. | |
| I've tried tinning with solder, if i give too much heat to the pcb, some oil (I don't know what to call) makes the solder not to stick on the metal on the pcb.
| Are you talking about the flux? | |
| Bitem2K: No, this is a liquid you drop in the PCB after etching and the whole PCB gets tinned. See the link, it should have more information on it. | |
| I've used the liquid tin too. Highly toxic, carcinogenic, and corrosive sh*t! Be really careful with it, and dispose of waste in a responsible manner. Although I'm a tough old codger, the fumes from this leave me gagging. Be CAREFUL! | |
| bananasoing, it's called oxides =) If the oxides are causing the solder joint to be difficult to make you're not using flux. Flux is a cleaner and protector for the joint under formation that prevents it from being exposed to air so that oxides don't form and ruin it, it also decays rapidly under heat. Most solders have a resin core which acts as flux the first time round, subsequent heatings require flux paste to be applied or the joint quickly deteroriates with exposed to the air heating, oxidizing it internally and make it brittle. The exact same thing happens during stick welding, a sacrificial flux resin is on the outside of the stick of metal to be welded preventing it from coming into contact with the air.
__________________ Superman returns.. | ||
| There is also an "Electrolysis Nickel Plating Solution". It Gives a Much Better coating than Tin, and with less Oxidation over time. Unfortunately its a Commerical Product and harder to buy in small quantities. A Professional Plating company MIGHT give you a bit.
__________________ I No Longer accept Private Messages on here. All Emails to me Must Contain the Word \"Electronic\" in the \"Subject Line\" or they go Directly to my Junk Mail Folder. Email me at: chemelec@hotmail.com Website: http://www3.telus.net/chemelec | |
| I have never heard of nickle plateing a PCB it's a crappy material to solder to. If you need corrosion resistance tin the board, solder it then coat it with a spray sealer.
Nickel Solders VERY Well with a Tin/Lead Solder.
__________________ I No Longer accept Private Messages on here. All Emails to me Must Contain the Word \"Electronic\" in the \"Subject Line\" or they go Directly to my Junk Mail Folder. Email me at: chemelec@hotmail.com Website: http://www3.telus.net/chemelec | ||
