Old 2nd February 2007, 08:08 AM   (permalink)
Default "new" scope screen all blurry - help
Just got my tek 2232 - I was so excited - my first scope - then, crap.
It powers up, and proceeds to show a bunch of blurry rectangles. Pushing the functions moves them around a little but that's it.
When I push the beam locator, I get a very bright, solid, vertical, rectangle. Everything is a rectangle, and turning the focus knob has absolutely zero effect.
I am so pissed at the ebay seller. The scope is not the one pictured in the ad, and they said "passed basic operation test". Hmm what operation is that? "yep, it weighs 10 pounds, just like the manual says. pass!"
Any idea what is wrong?
chancecasey is offline
Old 2nd February 2007, 09:05 AM   (permalink)
hi chance,
Some ideas, if you havn't already tried them.
Check the astigmatism control setting.
Check the mains voltage selector is set for your local voltage.
Low EHT is quite often a cause of focussing problems, if the CRO has been stored in a damp environment, the EHT could be leaking away.
Turn down the brightness/intensity until you can just see the trace.
Leave the CRO running for a few hours, to see if its a dampness problem.
[until you have confidence in the CRO, don't leave it unattended during this test].
If this dosn't work, turn OFF the CRO and disconnect from the mains.
Leave the CRO off, for an hour or so, remove the covers and using a 100K
resistor in series with a grounding wire connected to the CRO chassis, discharge any point you want to touch/measure, BEFORE you measure.
Do a visual check, of the CRO, a wire/connector may have come off in transit.
Take CARE the voltages can be lethal, dont work alone when doing the following checks.
If you have the manual, get a EHT test meter and check the EHT, and at the
tube base check the Cathode and Focussing potentials.[ and heater voltage]
If these all check out, measure the tubes 'beam current' , refer to the manual
for the value [ in the order of 100 to 200 microamps]
If this is low then I suspect you have been sold a 'turkey'
Regards
EricG
Let is know how it goes.
ericgibbs is offline
Old 2nd February 2007, 09:42 AM   (permalink)
I don't know what could be the fault but you can download a service manual from:
http://home.comcast.net/~aa4df02/download.htm
picasm is offline
Old 2nd February 2007, 06:27 PM   (permalink)
Found the astig adj, right next to the CRT. So let me get this straight, I turn it on, stick a metal screwdriver down in there where 5KV is nearby, and don't do it alone? Ummm, Yeah. Not feeling too good about this.
Old 2nd February 2007, 06:37 PM   (permalink)
hi chance,
If the 'astig' pot is internal there is a good chance to consider its not been disturbed, leave it alone at this time.
Many CRO's have a external user operated control, this is the type
to which I was referring.
Did you download the manual, I did for reference.
Regards
Eric
Old 2nd February 2007, 06:42 PM   (permalink)
ok - not the astig - i powered up, grounded anything i was going to touch with amp meter in series just to know those things are safe to touch, adjusted astig, no effect.
have not tried leaving it on for a few hours but nothing looks damp, guess i should try this next.
what is an EHT meter?
Old 2nd February 2007, 07:04 PM   (permalink)
oops - too late. how sensitive are those pots? i'm pretty sure i got it close to where it was.
Old 2nd February 2007, 07:06 PM   (permalink)
hi chance,
Basically an EHT meter is 'extra high tension' meter, designed for measuring kilovolts and it uses special probes to protect the user from electrical shock.
If you don't have access to the proper equipment/technical assistance and the damp 'soak' test dosn't cure the problem then you will have to contact your local repair shop.
Contact the seller and tell him of the problem and get his written agreement
that he is prepared to pay for the repair or get your money back or a replacement CRO that works.
Eric
Sorry to sound downbeat, but I don't want you to get injured trying to fix it, if
you dont have the experience.
BST: 19:20
EDIT: thanks for the response, good luck Eric
Old 2nd February 2007, 07:13 PM   (permalink)
no, I appreciate it very much. i know my limits. I already sent the seller an email - we'll see what they have to say. my crappy little multimeter is limited to 500V. guess i'll start looking for a shop - shouldn't be too hard around here in silicon valley.
Old 2nd February 2007, 07:16 PM   (permalink)
I assume it's ok to run the soak test with the cover off - as long as i give it plenty of room and don't touch anything?
i'm running the probe test/adjust square wave thing. If I crank down the seconds/div, I can kind of make it out, but, like I said, what should be a "line" is a solid rectangle.
Old 2nd February 2007, 09:04 PM   (permalink)
If you think it may be something wrong with the focusing section, then have a read of the newsgroup post below, it seems that they can suffer from burnt-out resistors in the focus circuit?
http://groups.google.co.uk/group/sci...e5f3fc610ff476
picasm is offline
Old 2nd February 2007, 10:03 PM   (permalink)
Well, the focus does absolutely nothing so it's worth a shot. Unfortunately my multimeter does not measure 500Kohm. The resistors do not look burned or brown, but a reading on the meter would be the only way to know for sure.
Of course, the thing may have been dropped and has a bad tube now for all I know.
Old 3rd February 2007, 12:10 AM   (permalink)
Does any used test equipment sold on Ebay work properly??
"If it breaks, sell it on Ebay"
audioguru is online now
Old 3rd February 2007, 12:29 AM   (permalink)
I hope some of its good. I've been trying to get a scope on there. This topic isn't real comforting.
Andy1845c is online now
Old 3rd February 2007, 01:39 AM   (permalink)
OK so I have some somewhat-good news. I went out and frapped down $50 to get a "decent" multimeter, and one of the 510KOhm resistors in series for the focus circuit is completely open - 20MOhm setting, still has infinity. I also picked up a selection of carbon comp resistors while I was there. I have to take the kids to Chuck E Cheese now (yeehah), but I'll post up the results of my repair work later tonight.
Crazy scope spuffock General Electronics Chat 28 25th August 2007 06:29 PM
selecting a scope, help! patroclus General Electronics Chat 13 27th January 2007 11:57 AM
Tv screen frequency abbarue General Electronics Chat 42 8th September 2006 12:52 PM
Digital and analog oscilloscope patroclus General Electronics Chat 34 12th July 2006 03:34 AM
HV scope probe question Oznog General Electronics Chat 1 14th October 2005 12:57 AM
