| Hi All, I have a large LED array encased in resin, it might generate a lot of heat.. What if I had the negative go via a large block of exposed copper at the bottom of the board to which I attach a heatsink to. Is this electrically safe.. will have like 6V, 4A going through it...... Perhaps I have a non-electrically conductive, but heat conductive paste between heatsink and copper... Just wondering how to dissipate heat if I have lots of LEDs in a matrix ( greater than 100 in one block with 5mm between each LED. The resin covers the board and a tiny bit of the LED casing. Peter | |
| don't know about heat sink paste, but you can get 'insulating' heat sink pads. they ensure that there's no electrical connection between the heatsink and whatever it's fastened to. most of the heat created by an led is dissipated throught the legs, and onto the board. . . so if the resin covers this, it may cause problems with heat transfer.? As for electrically safe? 6v isn't going to really do much if you touch it. But it's not good practice to leave any part of a circuit exposed. BTW: if it's on the negative side, it won't be 6v. It will be 0v
__________________ 'Intellectuals solve problems. . . Geniuses prevent them.' . . . Albert Einstein Last edited by fingaz; 1st February 2007 at 09:36 PM. | |
| Does each LED have its own current-limiting resistor? If the LEDs are 1.8V red ones then the resistors will be much hotter than the LEDs. If you don't have current-limiting resistors then the LEDs will all blow up. They are diodes, not light bulbs.
Peter | ||
If you are designing, why not try constant current sources for each bunch of series LEDs and such souces and leds can be more in parallel. Now the control devices can be outside resin(potting material-unless you deside to block access to circuitry) this will help optimization of power. instead of series resistors for each LED. you may perhaps consider this view point.
| If you're worried about short circuits then add a fuse or pollyfuse of the appropriate rating in series with your LEDs.
| I assume that he was asking if it is electrically safe to have the 'copper bar' on the negative side and the heatsink exposed.
__________________ 'Intellectuals solve problems. . . Geniuses prevent them.' . . . Albert Einstein | |
| Introduction to High Brightness LEDs and Thermal Management | Ocelaris | Electronic Projects Design/Ideas/Reviews | 3 | 17th March 2007 06:35 AM |
| Problems with Dual Brightness (Current) LED Tail Lights? Eagle Schematics! | Ocelaris | Electronic Projects Design/Ideas/Reviews | 12 | 31st December 2006 07:18 PM |
| Intrinsic safe power supply | Louis de Beer | Electronic Projects Design/Ideas/Reviews | 4 | 29th August 2006 03:08 AM |
| Safe and Stable 5V Automotive Circuit ? | iso9001 | General Electronics Chat | 10 | 3rd May 2004 11:45 PM |
| Need Help In finding a circuit for my Key Safe project Help! | fig | Electronic Projects Design/Ideas/Reviews | 0 | 22nd October 2003 04:50 PM |
