Old 1st February 2007, 02:51 PM   (permalink)
Question Astable multivibrator.
After hours of trawling the web, i have failed to understand how this works.
Could someone please explain it to me (in ultra simplified terms)?
Also whats the point of using a 555 if you can do this?
thanks very much
bitem2k is offline
Old 1st February 2007, 03:06 PM   (permalink)
try looking here, this explains in simple terms. . .
http://www.play-hookey.com/digital/e...l_astable.html
A 555 can be made to perform many different timing operations, not just flashing led's. try looking up 555 timer on www.google.co.uk to see how it can be used
'Intellectuals solve problems. . . Geniuses prevent them.' . . . Albert Einstein
fingaz is offline
Old 1st February 2007, 03:20 PM   (permalink)
Hi fingaz, thanks.
Unfortunately i allready looked at that site. Its the first one that comes up when i google.
I just dont understand the path that the current takes. I cant find anysites with good pictures.
I have looked at 555 timer sites, and have made several circuits involving the 555. Surely the circuit above can be employed for more usefull operations than just flashing leds?
I dont understand the differences between the two circuits.
thanks
bitem2k is offline
Old 1st February 2007, 03:25 PM   (permalink)
Try this- go here: http://www.falstad.com/circuit/ when the sim opens, select Astable multivibrator from the transistors menu.
Andy1845c is offline
Old 1st February 2007, 03:32 PM   (permalink)
Thanks mate, I was kind of hoping to get away with not installing the java runtime, ive only just formatted and re-installed everything, and its running sweet.
but ill give it a bash.
bitem2k is offline
Old 1st February 2007, 03:34 PM   (permalink)
Mate, your a lifesaver!
that apps great.
Cheers
bitem2k is offline
Old 1st February 2007, 04:11 PM   (permalink)
The difference between the two is, the astable can perform only one function. . . to alternate between on and off at a rate determined by the resistors and capacitors.
A 555 can do this, but can do other things too, e.g. wait for a specified time, then turn on. Or turn on for a specified time, then turn off. Or etc etc
Basically, the 555 is more versatile (than the astable transistor circuit), and often just as cheap, or cheaper than using transistors to perform the same task.
fingaz is offline
Old 1st February 2007, 04:30 PM   (permalink)
niceone.
thanks for the info.
bitem2k is offline
Astable Multivibrator Design fmang Electronic Projects Design/Ideas/Reviews 1 23rd August 2006 01:21 PM
connecting mono 555 to astable 555 dt General Electronics Chat 2 5th January 2006 02:34 AM
astable multivibrator to superregen mstechca Electronic Projects Design/Ideas/Reviews 3 24th March 2005 05:29 PM
555 astable question OverTech General Electronics Chat 5 17th May 2003 05:44 AM
How 2 connect 3 monostables to 1 astable? cuberoot Electronic Projects Design/Ideas/Reviews 3 9th September 2002 07:39 PM
