| I have a laser diode module that normally operates from two AAA batteries that produce a measured 1.27 mA at 3 V and I want to run it off of a 7-cell NiMH battery pack that produces a measured 5.3 mA at 9.56 V at full charge. (It's for an integral aiming device for an airsoft gun, in case you're wondering.) Given that I = V/R then 7k ohms of resistance should give me the proper amperage, but how do I reduce the voltage to the necessary level? Dan Last edited by Woodsman; 1st February 2007 at 01:13 AM. | |
| hi woodsman, To run your laser from 9v battery rather than a 3v battery, providing the current the laser draws from the battery is 1.27mA.[this seems low ???] Then you have to drop 6v across a series resistor, so 6/0.00127 = 4724 ohms the nearest preferred value is 4700R. Place a 4K7 resistor in series with battery positive to the laser positive input. Regards EricG Note: dont assume that AA batteries give 1.5v , alkaline will only give 1.2v also check your 9v battery, [ PP3 type] for voltage when you have got your resistor connected. Last edited by ericgibbs; 31st January 2007 at 09:44 AM. | |
| A small laser pointer operates at about 20mA to 60mA. The internal resistance of its button battery cells limits the current. Your current-measuring meter also limited the current so the laser probably didn't work. Maybe your "laser" is realy just a focussed LED. AAA cells have double the capacity of the AAAA cells inside a 9V battery. You will be throwing away 6V of battery power. A 9V alkaline battery starts at nearly 10V when its load current is low then quickly drops to 8V. Then its voltage continues dropping when it is loaded.
| Voltage | ElectroMaster | Electronic Theory | 44 | 8th August 2007 06:35 PM |
| boost converter overshoot / undershoot | justDIY | General Electronics Chat | 17 | 21st December 2006 05:50 PM |
| Voltage Clamp | ThirtyTwo | General Electronics Chat | 41 | 11th August 2006 05:05 PM |
| I am not getting ripple voltage at the output | dar2525 | General Electronics Chat | 3 | 14th July 2005 03:21 PM |
