Old 30th January 2007, 06:17 PM   (permalink)
Default Envelope Detector +fiber optic
I'm building an SCR based powersupply and I'm working through some of the control circuitry at the moment. I have it breadboarded and it works fine, now I need to modify it a bit.
The supply is for a tesla coil and I'd like to be able to control it from a safe distance. I could just keep the supply at a remote location and run the output straight to the coil, but I'd rather not have to haul the supply around.
I'm planning on using a 50' fiber optic cable for the firing angle control. The problem lies with the fiber optic reciever which has a minimum frequency of ~200kHz. My plan is to take the 120Hz variable width from the original circuit and 'and' it with a higher frequency signal. then use an envelope detector on the other end to just get the variable width signal out.
Does it look like it will work?
Jeff
jrz126 is offline
Old 30th January 2007, 06:46 PM   (permalink)
That should work, but you don't really need a diode, just a low pass filter on the input of the transistor will do.
Screen name: Aloone_Jonez
Hero999 is offline
Old 30th January 2007, 07:28 PM   (permalink)
You don't live in a town called Eureka do you?.
Simple Envelope Detectors EEEStudent General Electronics Chat 5 24th December 2006 12:57 PM
optic encoder and 16f628A. Help. MathGeek Micro Controllers 7 7th July 2006 07:42 PM
Envelope Detector ThermalRunaway General Electronics Chat 13 30th July 2005 07:25 PM
Video signal through fibre optic frankwas Electronic Projects Design/Ideas/Reviews 0 23rd August 2004 07:00 AM
fibre optic leds jon_jon_phenomenon Datasheet/Parts Requests 2 30th March 2004 03:23 AM
